Post your C450 with Aftermarket Wheels
#426
I found a wheel company called Signaturewheels running a special for $2999.00 and they will custom make my rim, I want to know if these will fit without any issues or spacers. rims are also super light he should me a 19X11 that was only 21lbs, so mine will be under 20. Think the front may stick out about 5mm.
19x8.5 ET30 with 225/40/19
19x10 ET48 with 265/35/19
For W205 sedan
For W205 sedan
#428
For W205 sedan
For W205 sedan
Please post pics i you have installed your wheels.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#429
20x8.5 ET31 245/30/20
20x10 ET50 275/30/20
#430
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x2000/img_6455_e33290f45194b384a34ad30759e5af0278842583.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x2000/img_6457_85df341040af858525f68d6ff2e0d6c6f8f34e20.jpg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_6458_c7dd3dc2285637765315c85dea609a878982e0e5.jpg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_6461_f5331f2c79d8e8e6028bb8c7821adaa3d6de2096.jpg)
Success! Everything was installed yesterday. My fronts came to +32 offset, rears at +55. I think +31 front offset would be best. The control arm clearance is really a pain... but, at least we can confirm that the part no. for h&r springs for c450 can be used on the c43. I guess someone has to update their website, haha!
Next issue is negative rear camber... i'm going back to the shop today, the alignment tech is gonna look for a solution to adjust the camber. I'm hoping camber bolts are avilable, but thats only for the fromts. Rears... well, again i'' crossing my fingers...
pics... just stance no close ups as the car was full of smudges, hahaha!
Mo your running those rims on these specs with no spacers can you take a picture of the front to see how far they stick out? Thanks
Fronts: 20x8.5 offset:+32; 245/30/20
Rears: 20x10 offset: +55; 275/30/20
I have someone making me rims with these specs
Fronts: 20x8.5 offset:+31; 245/30/20
#431
I am hoping I can find an answer here. I have a 2016 C450 and I am trying to find wheels. I found some on various sites but I am getting a little confused because some sites state "gauranteed fitment" and will have staggered options and other sites state the same thing for non staggered, but then won't gaurantee a fitment if they are staggered.
On 2 sites I show 2 fitments gauranteed for the same kind of wheels in this configuration:
19x8.5 F
19x9.5 R
and
19x 8.5 F&R
The site that guarantees fitment on the same size all around is carid.com which I have bought rims from many times but they won't guarantee staggered for some reason. Is there any benefit to going with the same size all around or is that a mistake on their end?
19x8.5 F
19x9.5 R
and
19x 8.5 F&R
#432
C43_AMG_NJ (03-19-2017)
#433
19x8.5 F
19x9.5 R
and
19x 8.5 F&R
19x8.5 F
19x9.5 R
and
19x 8.5 F&R
#434
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_7369_4f60dbceac85fc76d5b92ac0f27fc27b9ee1f558.jpg)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_7370_ff0e2f5fe9ea57ce58584e081014a927eb94a182.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_7371_3d744df9cac57f5daf3a3b2281d1800c24b30cb3.jpg)
#435
2015 C400
I had 19" AMG reps on my C400. They are still for sale.
$1,500CAD or $1,150USD with Continental Extreme Contact DWS tires
https://mbworld.org/forums/wheels-ti...400-450-a.html
#436
Any wheel fitment guru's out there help a brotha out?
Will I have any issues on my c450 with a front rim that is 19x8.5" with a ET45? They're coming off a c400 but I know that our AMG suspension upgrade makes fitment a nightmare so will it work fine or will I need spacers? And if so, how much, 10mm?
#437
Link to someone running a similar setup (ET42 vs your ET45) -https://mbworld.org/forums/c450-c43-...ml#post7039044
#438
10mm spacer will not be enough, because the wheel will poke out. If you want the wheel stay inside the wheelarches, you need min. 13mm spacers. ET32 is the max the wheelarches can have with wheels 8.5j width. ET30 is the best.
#439
What spacers will I need to have the rear stock 19s be flush? There's such a big gap of empty space between the stock rear wheels and the wheelarches
#440
Okay guys I found a wheel offering i like but am stuck between a few setup options and hoping someone can help. Would either of these setups fit a c43 coupe lowered on H&R and would spacers be needed with either:
Front: 8.5x19 ET options 35 or 45
Rear: 9.5x19 ET optios 35, 45 or 57
Can someone help me choose the proper ET values and what size spacers would be needed if any?
#441
#442
Remember these basic concepts:
The lower the offset the more the wheel pokes out. If there's one thing that confuses people about offset this is it.
AND
Adding spacers reduces offset by the thickness of the spacer. If there's another thing that confuses people it's this, because it's counterintuitive that adding something to a number reduces the number. A 35mm wheel with a 10mm spacer has a 25mm offset, not a 45.
You can never add more offset to a wheel with a spacer. You can only reduce it.
A millimeter is a very tiny unit of measurement. There are 25 of them in an inch.
I believe the factory C450 offsets are 33mm front and 52mm rear. The 35mm front/45mm rear option would get you closest to stock. The 2mm difference up front is nothing. The rears will move 7mm out (less than 1/2 inch) and there should be plenty of clearance. (The 57mm wheel would be further tucked in by 5mm, so I'd skip that option.)
Remember that if your aftermarket wheel is wider you need to figure that in. A 1" wider wheel adds 1/2" to the outside edge of the tire and 1/2" to the inner edge. (1/2" = 12mm).
If you take a tape to your existing wheel and measure the distance from the top of the outside edge of the tire to the inner fender lip, that's how much room you have to work with.
If it's 2" for example you can reduce offset by as much 50mm (1"= 25mm).
The wider rim eats up 12mm of that. 50-12= 38mm of space available on the outside edge of the tire to reduce offset and bring the wheel further out.
Reducing the offset number moves the wheel further out. Adding spacers reduces offset. More literally equals less.
You reduce offset in two ways. Buy a wheel with a lower offset. Or add a spacer to push the wheel further out (which effectively results in a lower offset).
For example, if your OEM offset is 45mm, and you buy a 35mm wheel, it sits 10mm further out than stock. If you keep your OEM wheel and add a 10mm spacer, it also sits 10mm further out than stock. Both have the exact same effective offset.
Generally try to avoid spacers by instead using wheels that are built with the desired offset. Sometimes spacers are unavoidable. They may be necessary to buy a little extra brake clearance. Try to use the thinnest ones possible. Adding spacers will also require new, longer lug bolts.
So in your case, presuming I have the right OEM offsets, and presuming the new wheel design clears the calipers, the calculation would go like this:
Front OEM offset is 33mm.
The new wheel is higher at 35mm.
The new wheel moves 2mm [iinward, closer to the shock tower.
The new rim is 1" wider.
The new rim moves 1/2" closer to the shock tower, as well as 1/2" closer to the fender lip.
You need essentially an extra 1/2" of space between your OEM front and the shock tower for your new wheels, and an extra half inch between the outside edge and the fender lip. If you make those measurements and you're within those margins, your new 35mm fronts will fit.
Rear offset is 52mm
The new wheel is lower at 45mm
The new wheel sits 7mm further out (52-45)
7mm is roughly 1/4"
The new wheel is 1" wider
The new wider wheel sits 1/2" further out.
1/2" + 1/4" = 3/4 inch
If you have at least 3/4 of an inch between your existing wheel and your fender, your new 45mm rears will fit.
Now let's say you want to go closer to flush on the rears. Your new wheels have an optional lower offset of 35mm. Will those fit? Well, they'd sit 17mm further out than stock (52-35), plus the extra inch of width adds 1/2". 17mm is roughly 3/4 of an inch. 3/4 + 1/2 = 1 1/4". So if you have at least 1 1/4" clearance between your existing wheel and fender lip, you can run the more aggressive 35mm rear safely.
Once you understand the basic concept of offset you can play around with all kinds of combinations to get exactly the look you're going for.
ionz13 (03-26-2018)
#443
I'll do you one better and tell you how to do your own calculations. (These are general fitment basics. Other owners of C450s with hard numbers are your best source of real world fitment issues. I know the C450 is a handful up front.)
AND
Rear offset is 52mm
7mm is roughly 1/4"
AND
Rear offset is 52mm
7mm is roughly 1/4"
8.5x18 ET49
So for the new wheels in the front I would ideally want an offset higher than 35 or 45 ET option offered. And by higher that would actually be a lower number such as 30 or 25-correct? Assuming that correct, I could also go with a narrower wheel such as a 8 vs 8.5 in the front in which case the ET wouldn't need to be as high. Hope I got that right?
#444
Wow-this is fantastic. Thanks so much for taking the time to explain all of this. The factory specs on the 18" wheels for the c43 i'm currently using are 7.5x18 ET33
8.5x18 ET49
8.5x18 ET49
For your calculations a higher offset (relative to OEM) moves the wheel inward. A lower offset pushes the wheel outward. Generally, a wheel that is pushed outward looks better. When you're doing aftermarket wheels you're looking to either hug the factory offsets, keeping the wheel position stock but changing the look of the wheel itself, or going more aggressive by nudging the wheels outward, improving the stance as well as the look of the wheel itself. You'd almost never want to go with a higher offset that tucks the wheel in more.
Lower offset number = Poke
Higher offset number = Suck
"Offset" refers to the position of the wheel's hub mounting surface relative to the wheel's centerline. If you had an 8" wide wheel, the centerline is at 4". If your wheel had its hub mounting surface (the back of the wheel where it meets the car's hub) at exactly 4", your wheel would have an offset of zero.
The offset number represents the distance of the wheel's hub mounting surface surface from the wheel's centerline. The further the mounting surface is placed toward the front of the wheel, the higher the offset. A wheel with a 45mm offset has a mounting surface that is 45mm away from the centerline and closer to the front.
The more you move the mounting surface closer to the front of the wheel, the more the wheel is drawn inward on the car. So if your car's OEM offset was 45mm and you chose a 35mm wheel, that moves the hub mounting surface closer by 10mm relative to the centerline, which causes the wheel to be drawn in less. That's referred to as "poke".
On your 7.5" fronts at an OEM offset of 33mm, going to an 8.5" will add 12mm to the width on each side of the wheel. So 12mm closer to the shock tower on the backside, and to the fender lip on the front.
The 35mm wheel will also sit 2mm closer to the shock tower. It's such a small difference it's essentially like running an OEM offset. The width is the only variable here. So if there's at least 14mm (12mm of extra width plus 2mm of extra offset) of clearance between the wheel and the shock tower (or any suspension bits) the 35mm wheel should work. Again, rely on the experience of the guys on here.
On the rears, going from a 49mm to a 45mm puts you at a minimal 4mm of poke. Add the 12mm of extra width and you'd need 16mm of clearance. (Around 3/4"). Should be fine.
ionz13 (03-31-2018)
#445
You're right. you need spacers to min. ET32, because else the wheels will touch the suspension arm. If you take spacers to 29mm and less, the wheels will poke out.
#446
Thanks again guys. So just to confirm: if I go with 19x8.5 ET 35 front with a 3mm spacer that will bring my ET to 32. And 19x9.5 ET 45 Rear with no spacers this setup should fit?
#447
W205C43AMGCoupe (03-24-2017)
#450
I'm going to pull the trigger on these and see how it works out, worse come to worse I'll need a larger spacer. I'll post pics once installed. For the 3mm spacer would that require longer wheel bolts? Are people still using H&R spacers? I saw a lot of spacers didn't work with this platform.
