W205 C63 Brakes on C450
I'm sure no one has tried this yet, but I wanted to see if anyone has some resources to read up on this subject.
I know the W204 C63 brake calipers bolted up to the W204's and expect the same in this instance.
Once I have some confidence that I won't run into any installation issues I'll look to procure a set of calipers.
I'll continue my search, I'm not 100% clear that is the same question. The only information there is how much a dealer charges for "AMG RED BRAKES" which may be the C63 calipers, or might just be some silly price for Red 4 piston C class calipers.
Normally clearance isn't an issue, but I'll look to dig up more data and get a better idea.
To be clear, I want the 6 Piston Front 4 Piston Rear calipers from the C63.
Again, thanks for the heads up.
I'm aware - this is not my first time doing something like this, first for a W205 but not overall.
I'm aware of the parts, I'm more than capable of doing the work myself, I'm just curious to get dimension so that I may calculate clearance and such before I purchase the parts and find out they won't clear my wheels, or require any sort of adapter. Some instances you need a different knuckle, and in the case of the C450 being AWD and the C63 not, you cannot simply use a C63 knuckle.
Hence why I'm looking for information beyond someone asking someone else for parts costs.
