C450 engine clicking noise
Palladium
Premium Package
Black AMG Leather Seats
Dark Ash Open Pore Trim
360 degree camera
Active LED Lighting System
I current have about 600 babied kms on it but I'm hearing a more noticeable clicking sound from the engine, almost like a knocking sound around 2000 rpms. It goes away if the rpm drops below 1800 or above 2500. This occurs regardless if the engine is hot or cold. Anyone else experiencing or have experienced this? Is this part of the break-in?
I hope this is not the same problem with the engines in the C300s?
Thanks in advance.
Its just annoying coming from a TL where the engine was quiet for the most part. Either than that, loving the car so far cant wait till 1,500 kms to open it up
Little concerned that it may be the valve or rod issue. Gonna get the technician to investigate. Anyone else notice that distinct sound at those rpm ranges?
My car has a clicking / pinging kind of noise on acceleration that the dealer diagnosed as rattling turbo wastegates. Both turbos and wastegates were replaced - but the noise remains. The dealer now takes the position that that the noise is normal wastegate noise. The shop foreman and I took a test drive in a E400 coupe - no noise, and he confirmed the noise in my C. I've had to live with it. It's hard to tell if the noise described by the OP is the same noise that I hear, but mine is definitely not the direct injectors clicking.
If you find out what is causing yours, please make sure you post it.
I'm slated to go back Tuesday morning when there is less traffic to pin point the noise.
Crossing my fingers hoping that noise does not come back.
Since then, I took my car to my dealership and tried hard to recreate the noise but couldn't get the conditions right to make it loud enough. My ears could pick it up because I've heard it before. I suggested to let the car cool and have another test drive to recreate the sound, this time it worked, but quietly.
The dealer said it was wastegate chatter and that it couldn't be fixed, but they could delay the timing of opening.
Since then, I've tried to live with it but it is so irritating along with the interior rattles... Every time I go for a night drive, I can hear the damn wastegate rattle and have just discovered a new whistle that is similar to gently blowing air.
This is definitely turbo related as I can hear it more frequently in Sport+.
@5Zigen18 @heyjoe, any solutions since then?
