Em I the only one with the Problem??
Old Jun 3, 2016 | 01:43 PM
bobhbenz's Avatar
c-300
Update, the vehicle has been in the shop now for four days, they are fitting the new brake rotors to the vehicle and are distressing the exhaust system and the engine mounts to see if it makes any changes. I was told there was one other case they found similar, and replaced the lower control arm, with AMG model. The saga continues...
Old Jun 10, 2016 | 02:34 PM
bobhbenz's Avatar
c-300
Update, Got car back yesterday after 9 days in shop, seems to be vibration free, I have driven on highway about 50 miles so far, I was told there is a TSB that suggest remove driveshaft turn 120 degrees and reinstall, remove all covers and heat shields under car and reinstall, replace front brake rotors, after all that they replaced the Conti's tires with Michelin Primacy 3ZP tires, so we shall see what the future brings...
Old Jun 16, 2016 | 01:01 PM
Mike C's Avatar
2016 C300 W205 Sport
Thanks for this post, Bob. I have a 2016 C300 sport with 450 miles on it and am experiencing the exact same issue, it's quite noticeable. Happens around 55-75mph only. I'm taking it in to the dealer next week, if there's a breakthrough I'll post it.
Old Jul 21, 2016 | 01:12 PM
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
I have started feeling a vibration at highway speeds in my car but I'm not sure it's the same one discussed in this thread. It is a very high frequency vibration, almost like a buzzing, that I can feel through the steering wheel, gas pedal and even seat. It occurs between around 110 kmh and 130 kmh. At other speeds it seems fine. I have the Conti RF's on 19" wheels. Doesn't seem to matter if I have the suspension in C, S or S+. The car only has about 1200 km on it.
I've experienced vibration caused by unbalanced tires or warped rotors before in other vehicles, and this is nothing like that. It's a higher frequency, kind of like the vibration of a cell phone, but it's constant as long as I stay in that speed range. It actually intensifies a bit when on the gas, and reduces a bit when coasting. It's not related to the road surface, as my highway route takes me over both concrete and asphalt paving, both new and old, and it doesn't change.
Any ideas?
I was planning on waiting a bit before taking it into the dealer, to see if it might be break-in related and hoping that it might sort itself out eventually.
Old Jul 21, 2016 | 02:07 PM
joe354's Avatar
C300
I have another post on here with this same issue. I bought my vehicle May 20th and it has been in the shop for 7 weeks now with them trying to resolve this issue. This week they are replacing some parts, not sure what as I didn't ask. If this doesn't fix it I'm going to call MB Customer Support and file a complaint. They are also refunding me 1 month lease payment because they've had it so much.
Old Jul 21, 2016 | 02:24 PM
Jdem22's Avatar
2016 C450
Hmmm this almost sounds like an issue Infiniti had with the 2011 G37X. Seemed the factory U joints had an issue that caused a vibration at highway speeds and in some cases a hum. You knew you had it if the rear view mirror became blurry above 50 (or more I forget) mph.
Old Jul 21, 2016 | 07:05 PM
  #32
flagman's Avatar
Would appreciate it if you could post an update when you get the car back. It would be good to know what the diagnosis was and what parts they replaced. Thanks.
Old Jul 21, 2016 | 07:17 PM
  #33
joe354's Avatar
C300
Will do..I just got a call and they are replacing the thrust arms. They received two left sides twice now this week and are having the correct part sent over night. They said they won't have it done now until Mon/Tue next week.
Old Jul 22, 2016 | 01:37 PM
  #34
flagman's Avatar
I hope that fixes it for you. Keep us updated. Thanks
Old Jul 26, 2016 | 06:46 PM
  #35
joe354's Avatar
C300
Quick Update: Dealer replaced left and right thrust arms. On the invoice it says strut rod and they say it resolved the issue. Haven't had a chance to drive it yet but will see how it rides on the way home today. I'll assume this resolved it but will update this thread if not.
Old Oct 13, 2016 | 03:50 PM
  #36
stopsignhank's Avatar
2016 C300
My car is in the shop right now for what sounds to be the same problem. When I am at a constant speed between 65 and 75 MPH I get a vibration in the steering wheel. It vibrates for a second, then stops for a second, then vibrates, then stops. If I go up to 80 MPH the vibration stops.
I happen to have 2 of these cars, both 2016 C300s. My wife's does not have this issue. I was able to show the manager of the service department the vibration. I just want them to fix it.
Old Oct 15, 2016 | 11:52 AM
  #37
auditoamg's Avatar
C63s
Sounds like lane departure assist?
Old Oct 16, 2016 | 11:00 AM
  #38
2016 C300
It is not lane departure assist.
Old Dec 20, 2016 | 08:45 AM
  #39
johnlk25's Avatar
2016 E400 4Matic
Any updates on what this is because I am having the same issue. I had the run flats on and my dealership removed the run flats and I had them install Michelin tires and I am still getting this humming, droning noise that starts around 65mph. So I know that it is not the tires. I also noticed that when I go over a speed bump, as the rear tires are coming off the speed bump, i feel a clunking in the steering wheel.
Old Dec 16, 2018 | 11:08 PM
  #40
Mike C's Avatar
Well uh, really late... It was the run flat tires. I'm kinda super pissed about the whole thing and my dealership was pretty terrible. Might be my last MB...
