How to upgrade the base sound system
My car is W212, T model 2010, some people here recommend to replace the front speakers with Infinity Kappa component 60.9cs, and rear with Infinity 6032si. What should I also install? Can they work correctly without installing amplifier? And the main question: I couldn’t find front speakers anywhere in Europe, and I’ve found only used rear speakers 6022 for 100$ in US. Can I use the other updated model of speakers that I can find in Europe? Who can help?
These speakers (HK) are sold on eBay Europe for my car, just for helping(size and what can be used like).
Take safe in this pandemic period of time.
Are you using an iPhone as a source? I found a really cool DSP app you might like.
interested to know what app you use
Thanks for your answer.
Mine doesn't have burmeister audio. I installed a Mosconi DSP, amplifiers, components and subs so virtually no stock sound system except for head unit. Roll off bass is very noticeable.
I had an audio control lc1 but had an awfull electrical noise and DSP is way better controlling sound.
How can this not be an option that can be disabled from the radio! Maybe through software update
Regards.
I think the signal coming out of the HU is so bad that it needs heavy mods to get the amp to work properly. Apart from the input EQ mods, I had to put the HU EQ to -10,-10,-10. It's only then that I got rid of the distortion that appears near 300Hz.
The dips, as you call them, were made by the software to compensate for the terrible signal coming out of the HU. Mercedes guys had to do heavy EQ mods to get the 1$ speakers to sound like 10$ ones (their guideline was - they still sound like crap, but most of the people won't notice).
Match UP 10DSP https://soundtech.shopping/products/match-up-10dsp
STEG BZ40A components https://stegaustralia.com.au/product...z-40a-speakers
STEG BZ40B surrounds https://stegaustralia.com.au/product...bz-40b-speaker
STEG BZ40C centre https://stegaustralia.com.au/product...z-40c-speakers
STEG BZW80 subwoofers https://stegaustralia.com.au/product...-20cm-speakers
Result = excellent. HUGE improvement and all the issues with the muddy bass are gone.
The only additional improvement possible would be the addition of full sized subwoofers instead of the Left and right footwell subwoofers, and then utilsing those 6 inch foot well speakers as mid bass , which can be manipulated with the amplifier/DSP's software, but this would involve either a custom solution to the trunk/boot or an off the shelf solution - either of which would not be stealth . The above solution is a simple speaker and amplifier upgrade and is completely stealth, and leaves the boot/trunk space untouched. And the sound is very very good
Location Sydney, Australia
I have been reading the forum for some time and started look around on the internet and saw a video of ETON subs replacing Burmester subs. They are made in German and they do not have a dealer in Canada, where I'm located. I told myself that Burmester can't handle my music and they way I like to play it, so I bit the bullet and messaged ETON and they redirected to a dealer in California who was amazing.
I asked for a deal and they gave me one and I ordered my ETON subs. I installed them myself and since I already had the experience, I can tell you the driver side carpet is the hardest to get back in.
Well, now I have the ETON Subs installed and I'm so happy because I now longer have to set my bass at Max as these subs hit HARD. I was thinking of Focal but they are produces the same way as the Burmester subs = paper woofer style whereas the ETONS are have a polyfiber woofer design which allows each sub to run at 2 ohms and pump out 200 Watts per sub which from the Stock Burmester, there is no comparison. ETON was the right way to go, plug and play and listen to the hard hitting bass.
