How to upgrade the base sound system
I cut up some splitters so that I had two plugs: one for the speaker and one for the tweeter cable, and one receptacle for the wiring harness plug. The receptacle is the wrong shape for the wiring harness plug, soI had to remove the shroud to expose the pins, like picture two below, which shows three versions of 'female' receptacles with pins. The pins then plug into the wiring harness plug.
[aside: I know that I am over-complicating the explanation, because the standard notation of calling a plug that contains pins (like that on the speaker and the 2 plugs on the crossover) "female' makes no sense to me. to me if it has pins, it should be male and if it has holes it should be female. However the normal notation is if the plug sticks in it is male, whether it has pins or not. But when I cut off the shroud to expose the pins then inserted it into the harness plug, gender became unclear. Much ado about nothing I suppose.]
A real audio person could comment, but I think you want to make sure both the mid-range speaker and the tweeter are in phase---of consistent polarity. The connector on the mid-range and the tweeter have a stop to ensure the harness plug only fits one way. (see right had side of speaker plug in photos). I tried to ensure that by making sure the red wire of the male connector was in the same relative location on both the mid-woofer receptacle and the tweeter receptacle.
The ebay listing is titled: Match Audiotec Fischer PP 62DSP Plug & Play Amplifier + Free Harness Mercedes
About as clear as you can get. Now if it just works...
As for others worrying about the door speaker plugs, unless you plan on placing the stock speakers back one day (unlikely), just cut the stock wires and split/divert them.
Suggestions welcome.
Also, thank you to all who contribute to this thread, this has been incredibly helpful.
My GLC300 sound setup and trim seems very close to the C class, which is why I am posting here. The author of the video apparently ties into a door speaker cable for the signal, but I didn't watch that far. I suppose you could also tie into the front bass, because it is near where he runs power through the passenger firewall.
I wasn't too interested in this option because it does not address the missing midbass. My issue with the sound was not so much that low bass was weak, it is, but that the overall balance was poor: lack of highs (no stock tweeter) and no midbass ( word has it that everything below a few hundred hz goes to the front bass). All my music sounded like it came from a 1940s acoustic recording
Any comments on the center speaker installation will be appreciated, as will that of the surrounds---I assume they are for the rear pillars, between the rear window and back doors.
Oh, and thanks for the answer on power routing. I think there is a grommet in a similar location on the glc. I will look tomorrow or saturday.
I have no idea how much is the improvement would be ? is it noticeable ?
knowing that I will keep using the factory amp and head unit, only the 9 speakers will be replaced
your feedback is highly appreciated
amp ? watts ? voltage ?? all the data about it
thanks
- 4” midrange & 1” tweeter left front door passive crossover*
- 6” subwoofer left front footwell
- 4” midrange center dash
- 6” subwoofer right passenger footwell
- 4” midrange & 1” tweeter right front door passive
- 4” midrange & 1” tweeter right rear door passive
- 4” midrange left parcel shelf (left surround)
- 4” midrange right parcel shelf (right surround)
- 4” midrange and 1” tweeter left rear door passive
The harsh front bass is softened a bit, but still needs tuning to not sound like beating a cardboard box. I turn bass to 10.
Note.
For some reason the Match tweeters and the Match front subs are wired opposite to the stock Burmester ones.
I made adapter cables to reverse them using Aliexpress connectors for MB speakers so they match the corresponding mid speaker polarity. (when tested)
Also, the Match subs are 4 ohm each but the stock OEM front subs tested at 2.2 ohms each.
but i would like to know about the base sound system ..
what matters with me is that i wanna know the stock non burmster amplifier whether it is there or not
coz i read on some threats that for the base sound system there is no amplifier ... while the head unit is feeding the speakers with the power and one more then i read also there is no subwoofer at the drivers side
i am little bit confused .. about all this ...
i want simply to improve my sound system by only replacing the speakers so that i dont void the warranty ..
https://www.crutchfield.com/cart/def...&emKey=2394217
there is a duplicated item in the cart just ignore it
and here is my vin nnumber
WDDWF6EB5GF272630
please check if there guys offered my the right thing
