Collision Prevention Assist
I also asked the dealer if there's a way to test to see if the actual breaking would work if I'm about to encounter another car, I could not get a straight answer out of him as to anyway to effectively test.
If your looking to test the system find a good stretch of road that is not being used. Maybe behind Walmart or behind a huge plaza where the trucking bays are. Be sure to find a huge inflatable item, something that is soft and can be found in the pool area of a store. The inflatable only has to be the size of a child, not the size of a s class tail end.
It's still too sensitive for my liking but at least it does warn me if I come up to a car too fast.
i dont think you can change the sensitivity...i think that becomes a liability issue. if you are allowed to change that kind of safety feature, i imagine it would open up all kinds of lawsuits when "i rear ended this car because the dealer must have accidentally changed the sensitivity" or some bullsh**
I never had it break unnecessarily.
To me the system works perfectly. The false warnings i get don't bother me.
It might be that your radar is a bit more sensitive than usual and picks up debris.
I can imagine the number of false alerts you get are annoying.
The response of the system is also depending on the responsiveness of the driver. The less active the driver, the more responsive the system gets.
So if you let go of the accelerator or take an evasive action when approaching the box it might not or respond later.
This would be the cheapest and safe route in my opinion as well
