Fitting Cla Wheels on my C Class
Old Aug 12, 2016 | 04:15 PM
berksus's Avatar
W205 C Coupe
I want these cla 200 wheels, and I am wondering if these wheels with 52mm offset would with my w205 c180 coupe. Do you have any ideas that you can share?
Old Aug 12, 2016 | 09:31 PM
Mike5215's Avatar
2016 C300
Being a FWD car the offsets for the CLA are high relative to the C, especially up front. MB makes a lot of wheels with the same face but different offsets. I'd shop around.
Old Aug 12, 2016 | 09:52 PM
B2FiNiTY's Avatar
'16 GLC300
First find out the stock size width and offsets and see the difference. Most likely they will fit.
Old Aug 13, 2016 | 03:40 AM
berksus's Avatar
W205 C Coupe
These are the values for my c class wheels
225/50R17 7Jx17 ET48.5 5x112 M14 x 1.5 66.6
And, these are the values for the cla wheels that I want to get
225/40R18 7.5Jx18 ET52 5x112 M14 x 1.5 66.6
Would they fit with these offset and other values?
Old Aug 13, 2016 | 11:07 AM
B2FiNiTY's Avatar
'16 GLC300
It looks like it will fit. One size up. The width is slightly higher but the offset is also higher so it is pretty much comparable.
Old Aug 13, 2016 | 03:01 PM
Mike5215's Avatar
2016 C300
The higher offset moves the wheel 4mm closer to the strut. The extra 1/4" width on each side moves it an additional 6mm closer to the strut, so if you don't have 10mm clearance now between the top inside edge of the wheel and the strut these wheels won't work.
Generally if you're changing wheels you're doing so to improve the aesthetics. Going to a higher offset wheel tucks the wheel deeper into the wheel well. Most owners want to improve the stance by widening the wheels outward. That requires a lower offset wheel.
You want to either match your current offset or go lower. If you go lower, the clearance issue is the space between the outside top edge of the tire and the inner edge of the fender.
Old Aug 14, 2016 | 04:18 AM
berksus's Avatar
W205 C Coupe
If my wheels get 10mm inside, it is not a problem for me. Just wondering will it look funny because of this or will it be just a small aesthetics difference.
Also, if I calculated correctly wheel is 10mm closer to inside, and extends an extra 2mm to outside because of new wider wheels.
How can I measure the distance between the wheel and strut.
Old Aug 14, 2016 | 06:28 AM
B2FiNiTY's Avatar
'16 GLC300
You can always get spacers.
Old Aug 14, 2016 | 08:10 AM
berksus's Avatar
W205 C Coupe
I have been told that spacers would cause problems in the long run. Is it true?
Old Aug 14, 2016 | 09:59 AM
ItalianJoe1's Avatar
2003 CL 600
you'd have to physically measure to the strut, with the car on the ground/ramps so the wheels are in normal position. There may not be a lot of clearance, but there are also many w205 models with larger wheels than yours so i'm fairly certain it will fit just fine.
Put your hand behind the tire and feel for the strut. If there's more than a finger width gap you should be fine. Or run a small 5mm or so spacer so it will barely move in.
There's no inherent problem with spacers, if properly installed they do the same thing as purchasing a wheel with more offset built in.
Old Aug 14, 2016 | 10:11 AM
Mike5215's Avatar
2016 C300
I've run spacers on my previous W220 and W221. You're adding more rotating mass that cannot be balanced like your wheel and tire can. Up front, you're more likely to introduce vibration. It may be negligible or tolerable depending on how much that stuff bugs you. Personally I'll only run them on the rears.
Avoid spacers and hub rings if at all possible. Much smarter to choose a wheel with the offset you're looking for in the first place. If you've got a line on a specific set of those CLA wheels for an unbelievable price I'd do spacers and hope for the best. Otherwise not.
Old Aug 14, 2016 | 11:05 PM
janusgrimnitz's Avatar
C200 4matic
Had spacers on my car for 1 day and took them off.. The tiny vibrations drove me crazy
