Traction control off
Old Aug 17, 2016 | 07:20 PM
Marco Torino's Avatar
c205 c300 coupe
Good day,
how do you (can you) turn traction control full off?
I found esp off in the menus but does that mean the traction control is fully off?
Old Aug 17, 2016 | 07:34 PM
GerritKw's Avatar
C350e
Originally Posted by Marco Torino
Good day,
The manual states that the traction control is not disabled when ESP is disabled.
I can imagine that for AMG versions there are additional settings. However I cannot find them.
Old Aug 17, 2016 | 10:22 PM
DBOC205's Avatar
W205 C250BT
Put the car into Dyno mode (via the service menu) - all the traction stuff is turned off until the next ignition cycle
Old Aug 18, 2016 | 03:09 AM
c205 c300 coupe
How do you do that?
I can find it.
Its a c300
Old Aug 18, 2016 | 03:19 AM
DBOC205's Avatar
W205 C250BT
How do you do that?
I can find it.
Its a c300
Service menu:
  1. Turn on ignition
  2. Set the instrument cluster to show odometer mode.
  3. Press and hold the "accept call" button, then press and hold the "OK" button. The service menu should appear after a few seconds.
If you can't get it, do a search on Youtube - there's a few vids on there that show you how it's done.
You'll find "Dynamometer test" mode within that service menu.
Old Aug 18, 2016 | 03:41 AM
c205 c300 coupe
Thank you very much,
so with esp off you turn just a part off and with this everything is off
What does only esp off let you do with the car?
Old Aug 18, 2016 | 10:01 AM
topsider's Avatar
2015 C300 Sport 4MATIC
Service menu:
  1. Turn on ignition
We dont have that in the US unfortunately
Old Aug 18, 2016 | 06:14 PM
DBOC205's Avatar
W205 C250BT
I don't believe it. Are you sure you're in the service menu? What are the options under your service menu?
Old Aug 18, 2016 | 08:18 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Good day,
Pull the ABS / TC fuse.... don't complain if you stack..
Old Aug 29, 2016 | 07:35 AM
c205 c300 coupe
Service menu:
  1. Turn on ignition
I read on the internet that dyno mode turns off differential lock and that is not possible to drift with the open diff.
is this correct?
Old Aug 29, 2016 | 09:35 AM
topsider's Avatar
yes, i am positive. The service menu only has messages, tire pressure, and assist plus
Old Aug 30, 2016 | 04:51 AM
Shadwell's Avatar
You need to be in the home position then select it then scroll to get odometer up NOT home and scroll down to service..... Pretty sure it's there...
Old Aug 30, 2016 | 09:22 AM
topsider's Avatar
there might be a different way to to it as there is with the C450 but it definitely isnt in the service menu on US C300's
