Stiff steering?
Old Sep 10, 2016 | 03:28 PM
Popcrnchicken's Avatar
W205
Stiff steering?
Hello all,
Something I have found to be uncomfortable about my c300 is that I'm constantly wrestling with the steering wheel. Whenever I go to turn the wheel, it's fighting me to get back to the center. Now I know a car does this naturally, but my other cars are more "gentle" about doing it. When I'm turning in the c300, I have to use a lot of my hand muscles to keep it turned, or it will sling back into the center quickly.
Has anyone else experienced this? Does this type of steering just come with the territory of owning a Mercedes, or is this something I should look into? I also have a 16' X3, and the steering is smooth and never an issue.
Old Sep 10, 2016 | 03:35 PM
Cbc200's Avatar
2020 GLE 350d AMG Line Prem+
Hi,
I find my steering to be very smooth and is easy to turn, it certainly doesn't fight back as you say yours does.
I have driven other family members cars - new mini and a new golf and I have to say compared to those my steering is much lighter and easier to turn.
Possibly go into the dealer and ask to test drive others so you can compare it to your car?
Old Sep 10, 2016 | 03:40 PM
PeterUbers's Avatar
Originally Posted by Popcrnchicken
Hello all,
none of my Mercedes' have done this ... Take to dealer and have tech drive it with you in car
Old Sep 10, 2016 | 03:53 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
I find mine to have a slightly heavy feel when moving off centre. Its not smooth like my BMW is. Once the wheel is moving its smooth and light, but there's definite resistance from centre which at times makes me feel like wheel alignment isn't quite right... when I know it is.
Old Sep 11, 2016 | 12:50 AM
jlr82's Avatar
2018 C300
I know what you mean, this was my biggest gripe with the W205 over the W204 was the way the steering feels when trying to snap back to center. It's just the way they are, but they weren't always that way.
Old Sep 11, 2016 | 10:00 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
I've never felt that on either of the two C300's I've owned, or on the two loaners I've driven extensively. If anything, I find the steering on the light side ... although it does get slightly heavier off center.
Have you had your car's alignment checked?
Old Sep 11, 2016 | 11:34 AM
W205
Could an alignment be the issue?
Old Sep 11, 2016 | 05:16 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Unless the car severely swerves off the road when you let go of the steering wheel, I doubt it.
My steering feels fine. No overly aggressive pull back to center.
Old Sep 11, 2016 | 06:18 PM
JBMCL's Avatar
Benz
I think you should bring it to the dealer and get it checked. Mine is very smooth and light as well.
Sometimes I think it's a little too light..
Old Sep 11, 2016 | 07:46 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Too much toe in or too little toe out would make the steering feel heavier in the dead ahaead and not necessarily pull left of right...
Mine had too much toe in, was heavier through the steering and scrubbed its tyres..
Felt it imediately and had the dealer check alignment, sure enough, too much toe in, they corrected it to optimal factory spec (ie mid range) and both the weight and scrubbing were improved markedly..
I requested they rebalance the wheels to to account for the uneven wear..
NOTE they also went full top end factory spec on the ptressures to to try and aleviate some of the wear.. (ie move it central) to extend the tyre wear life, but the road feel was horibble and harsh.. i corrected to factory normal (single passeneger min load, normal speeds).. vast improvement...
Summary have they check all the basics first..
Best of luck resolving your issue.
Old Sep 12, 2016 | 11:37 AM
topsider's Avatar
2015 C300 Sport 4MATIC
mine is very light. Where as in my old e90 it was so heavy that I it felt like the power steering was off.
Old May 4, 2024 | 08:40 PM
Glcguy's Avatar
GLC300
How did you fix this? I have same difficulty with glc300 2022
Old May 13, 2024 | 09:56 AM
sids2112's Avatar
2021 C300 4MATIC
I know what you mean. When I switch to Michelin A/S4s my steering gets this way too. It’s smooth, lighter on winter tires. Idk how much tires influence this, but it can be an annoying effort to make sharp turns at low speeds in parking lots.
