Here's the details of the alarm siren. Not sure if that'll get you what you want. You'll need to remove the rear liner section on the right fender to see it.
Silly question, but why not get this sorted under warranty if it's a 2016 car?
Sounds more like someone who wants to know how to disable the alarm for other purposes.
If it goes off every day you should be able to hear where the sound comes from.
Nothing in the factory system should cause that. Perhaps someone installed an aftermarket alarm with a shock/vibration sensor that is set too sensitive.
