Help! My oil filter paper insert is stuck with cap
Old Nov 1, 2016 | 01:11 PM
masupra's Avatar
GLC300
Doing first oil change using an extractor. All went well until I try to remove the paper filter insert from the oil filter cap assembly. I checked the new filter, there's no hook or anything, but it's stuck extremely tight, no amount of pulling, turning, can break it loose. I am pulling so hard that I am afraid the long plastic stick in the center will break from the cap. I am at the point of trying to cut it but don't know if there's any implications.
I searched old posts but they all seem to be about oil cap stuck with housing. No one ever had my issue. Any tips?
Attached Thumbnails Help! My oil filter paper insert is stuck with cap-122.png
Old Nov 1, 2016 | 02:58 PM
miketc's Avatar
W205
I have no issue with turning the paper insert counter clockwise while pulling down on it. Good luck.
Old Nov 1, 2016 | 04:10 PM
masupra's Avatar
GLC300
I wonder if it makes a difference when the filter is hot or cold. I was doing it while engine is cold because I wanted the oil to drain back as much as possible to avoid a mess while trying to take it out.
Anyway, it seemed just impossible to simply turn and pull out. So I ended up cutting the paper of the old filter from side. Once enough paper has been cut, it appears to have release the tension and I was able to twist it off.
The only issue is, while doing the cut with a knife, I mar'ed the surface of the plastic insert slightly. Would it be an issue? I wonder if the smooth surface has anything to do with having the oil flow at intended rate or whether a mar'ed surface will lower its structure integrity under high heat and pressure.
Old Nov 3, 2016 | 08:15 AM
miketc's Avatar
W205
I changed my oil while cold so that's not it. What plastic insert are you referring to that was marred?
Old Nov 3, 2016 | 11:44 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
I have had one that was easy off and one that was very tight.
After some messing about it loosened off.
