View Poll Results: RUN FLAT OR NON RUN-FLAT TIRES FOR C-CLASS W205 ?
RFT
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
5
29.41%
NON RFT
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
12
70.59%
Voters: 17. You may not vote on this poll
ULTIMATE THREAD! Run flat tires or not RFT tyres, what is the best choice for you ?
Hi,
Still wondering if I should select runflat tires or non run flat tires for the C-class.
Have you changed yours ?
It's clear that RFT tyres are not as comfortable but it's obvious that they are safer, so what do you choose between RFT or non-rft tyres ?
Price ? Do you really care the price when you own a Benz and the price of what could save your life ?
Waiting for your ideas to know if mine are fine :-)
Thank you !
Thank you !
While I understand the compromises in RFT design, I have stayed with my OEM tires and won't consider non-runflats until these wear out.
In the event of a flat, which is rare, do I want to be able to drive to a safe spot or be compelled to deal with the situation wherever the tire fails? I recently had a front tire pierced by a large bolt and was able to drive to a garage where the tire was able to be plugged. In a few minutes I was back on the road.
There's no question that RFT's are less compliant and therefore give a harsher ride. You can also get a much larger range of tire options with standard tires .... from high performance summer tires, all-seasons, to snows. It just comes down to how you react to the performance of the RFT's you have on your car. In my own case, I'm fine with them for now and will reconsider that when the time to buy new tires comes.
Replaced mine almost immediately with Michelin Pilot Supersports. I've ran them on every Benz I've owned (04 S430, 06 S500, 10 S550) and I've become spoiled by them I'm afraid. They ride and handle like no other tire I've tried. And I've tried a few, because the Michelins aren't cheap!)
I bought a Seal & Fill kit since there's no spare. Anecdotally I've put over 200,000 miles on MPSS over the years and never had a flat, but of course it is possible.
On a 205 with AirMatic the ride becomes very S Class like on them.
Ejbrock
I also run Michelin Pilot Supersports and am very happy with their performance. I also fill them with nitrogen.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Hi,
Thank you !
Thank you !
Still feel weird that comfort is for most of you more important than security.
As far as a typical flat, a Seal & Fill kit can repair a puncture and reinflate the tire. In the event of a sidewall rupture or anything else that damages the tire structurally beyond just its capacity to hold air, a run flat is just as useless as a conventional tire.
Incidentally, because of their extra stiff sidewalls, the run flats are much more prone to sidewall ruptures in the first place, especially on 19" wheels. Tons of threads on here about guys with multiple sidewall ruptures and tire replacements.
But if it would just drive you crazy with worry about getting a flat from a puncture on non run flats, don't do it. The trade off though is a harsher ride, shorter tread life, extra cost, more noise and a greater potential for blow outs.
I don't think there's any debate over the performance and comfort superiority of non-RFT's over RFT's. In many situations, especially if the sidewall is not damaged, an RFT can get you to a service facility safely when punctured. A non-RFT will require either a call for help or some sort of inflation/sealant kit. Ultimately, they are a rationale for manufacturers to avoid including spare tires and jacks with new cars. They do offer a solution, but one that is not always reliable.
For me, the question is simply about incurring the additional expense of replacing the tires on my car before they are worn. I run non-RFT snow tires during the winter months ... which here is late November through early April. When my OEM tires need replacing I will probably consider replacing them with standard all-seasons rather than summer tires, simply because we can get very cold temperatures almost any time of the year. Again I agree the RFT's have as many disadvantages as advantages, but I will wait until it's time to shop for new tires.
2021 E450, 2020 C43, 2015 C300, 2007 C280
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
I don't see many Luxury trim C-Class around here. I also realize that not many MBWorld readers have full-height sidewalls. So those of you who have already compromised your comfort for a sportier appearance (and maybe can actually use sportier performance) have a more difficult choice.
The car that got me thinking about a 205 was a base loaner car on 17". That car, on a steel base suspension just slightly stiffer than lux, had a great balance of comfort and handling. By the time I spec'd out my build I had the Sport package for aesthetics, with 18" wheels and AirMatic to take the edge off. That plus the tire swap got me about 80% of the ride quality of the base car on 17's. I was coming from a series of S Classes so my standard for what constitutes ride quality is a little (or a lot) skewed.
