C400 - tire pressure monitor
Old Nov 15, 2016 | 11:18 PM
sbcal403's Avatar
Merc c400
Is the tire pressure monitor sensors and the tires were built into the hub system?
If I get winter tires and wheels do I need tpms in the tires itself
Sb
Old Nov 16, 2016 | 07:06 AM
MASSC450's Avatar
2026 GLE 53 Coupe
Tire pressure monitor sensors (TPMS) sensors are attached to the wheel itself, not the tire. The battery/valve stem is one piece, and it's held on the rim by a nut on the valve stem.
If you don't install TPM sensors on your Winter wheels (either buy another set or carry over your existing ones), you won't be able to see your tire pressure in the driver's display and warning light will come on and remain on. If you decide to buy a new set, ensure you buy the correct ones. You can get sets of four on ebay for about $150.
Old Nov 16, 2016 | 11:42 AM
sbcal403's Avatar
Merc c400
thanks
thanks dude. exactly what i wanted to know
sb
