Push Button Start - no Start
Old Nov 28, 2016 | 08:54 AM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Had an unusual occurrence on Friday morning. Went out to start the car using the pushbutton. All indications of a start happened...ie...tach and speedo rotated with the normal red arch, lights came on (car was in garage), air came on, radio came on and all normal warning lights came on momentarily as per usual. No engine start...not even a wimper from the starter. I tried it 2 or 3 times with the same result.
Popped off the pushbutton and inserted key and had a normal engine start.
After I got to my destination I reinserted the pushbutton. Subsequent engine starts using keyless go have been normal since then. I have not changed the fob battery.
I've had keyfob battery issues in the past but with a dead battery in the fob I got nothing, no instruments etc, along with the no engine start.
Anyone else seen this situation? Right now I'm just chalking it up to...hmmmm...that was interesting.
2016 C300 Sport 4matic.
Old Nov 28, 2016 | 11:44 AM
Mikey53's Avatar
Veteran: Air Force
Originally Posted by Plutoe
Maybe where you placed the fob on your person, the signal could have been blocked!!
I doubt if for the same reason I don't think the battery in the FOB was an issue. If the signal was blocked, I wouldn't have gotten all the other indications of an attempted engine start.
Plus, I had the key laying in the center console.
Old Nov 28, 2016 | 12:25 PM
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
I had this happen to me twice, about 2 months apart. There was only one non-start each time - I didn't even have to pop off the button, I just shut everything off and did the normal "foot on brake and push button" again and it started. Will certainly mention this to the dealer when my car is next in for service. There should be a fault code stored.
Old Nov 28, 2016 | 01:18 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Press the brake pedal harder before pressing start.
Old Nov 28, 2016 | 10:47 PM
auditoamg's Avatar
C63s
I thought there was a software update way back... Could this be the issue???
Old Nov 28, 2016 | 11:45 PM
SoDakBenz's Avatar
2015 C300 Sport 4Matic, 2014 C300 Sport 4Matic
My car did something weird twice over the last month. Get to my destination and shut car off like normal get out hit the lock on the handle it beeps go into the store come back put hand on handle it unlocks I open door and the radio is playing. Not sure how or why. Thought maybe I didn't actually shut it off but I know for a fact I heard the alarm beep.
Old Nov 29, 2016 | 08:44 AM
Mikey53's Avatar
Veteran: Air Force
I had a software update shortly after I got the car that addressed an issue with keyless go (doors locking/unlocking) only working about 50% of the time. That issue has never resurfaced.
Old Nov 29, 2016 | 09:10 AM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
When my GLC was a couple of months old I had the identical problem.
Called the M-B help line. Reached a professional lady, who after detailing my problem, advised me to remove the start/stop button. When I couldn't get it out she told me to pull harder. When I removed the button she told me to attempt a start using the key, which was successful.
Have had the vehicle nine months at this point with no recurrence.
Old Nov 29, 2016 | 10:00 AM
Mikey53's Avatar
Veteran: Air Force
The button on my C Class comes out quite easily and I had no problem starting the motor with the key.
Unless it reoccurs I'm just going to chalk it up to gremlins not having their morning coffee that day.
Old Nov 29, 2016 | 11:14 AM
Veteran: Air Force
Solid logic.
By the way Mikey I very much like your avatar.
When I was in Viet Nam I witnessed a three aircraft B-52 bomb run from about 20/25 miles away from the base control tower. Damm scary! The VC called them silent death.
Old Nov 29, 2016 | 12:21 PM
Mikey53's Avatar
Veteran: Air Force
Solid logic.
I have about 2500 hours in the Buff (including the "D" model) but it was post Viet Nam.
