I picked up this phone mount recently and I think it's the best one yet. The location is nice and does not block the a/c buttons, if you had a note or a phablet type phone you'll have to position it some way to not block the screen or buttons too much. The magnet is strong enough to take hard acceleration and curves at high speeds. Went on a cruise this weekend on some bikers route and it handled well. Looks low key when the phone is not attached. It comes with some spacers so it can fit a bit more snug between the screen and the vents. Technically the spacer wasn't needed but I want it a little more snug so I used it. I had to sand it down a bit to fit perfect.
You can find more pictures with a phone on it on amazon:
I've looked at alternate mounts but none have a very elegant way to handle the cable, and I want to go direct from the device into COMAND via USB for audio (and charging). The ProClip's drop in mount with integrated lightning cable seems to work best.
HI WHERE DO I PURCHASE ONE OF THESE FROM AND WILL IT FIT MY SAMSUNG NOTE 9 INSIDE IT PLEASE
I managed to pull this off with the larger COMAND screen. I purchased the same mount and had to shave some of the clip down with a dremel then used some interior cleaner as lubrication to get the fins in between the trim. Hope this helps!
http://joli.design/
Looking for a mount for my car, I have just been leaving my phone in the cup holder. Has anybody tried this mount yet? It looks pretty nice and no real modification needed
