Phone Holders for C-Class
Old 12-07-2016, 11:28 PM
FastE's Avatar
2020 MB-AMG GLC43
I used a product from Pro Clip USA in my E550 (W212) that was awesome. Unfortunately they don't have a nice looking solution for my C43 (W205).
Does anyone have a favourite to share?
Old 12-07-2016, 11:37 PM
Mike5215's Avatar
2016 C300
I have the Pro Clip console mount and an IPhone 6 drop in cradle. Snaps into the right side of the center console. Works great. If you still have the cradle all you'll need is the mount.
Old 12-07-2016, 11:55 PM
FastE's Avatar
2020 MB-AMG GLC43
Is that the clip that is really long on the right side of the console? It looks odd in pictures. More info would be great if you can send a picture. Thanks.
Old 12-08-2016, 12:07 AM
FastE's Avatar
2020 MB-AMG GLC43
ProClip
Is this the one you have? I chose this image because it looks odd on the passenger side. I have the open pore wood grain, which changes the part.
Old 12-08-2016, 12:10 AM
Mike5215's Avatar
2016 C300
Yeah I have open pore too. That pic with the flash makes the mount look much more prominent than it is. It also looks gray in the pic but it's actually a solid black. I'll get a pic in the AM.
Old 12-08-2016, 10:01 AM
FastE's Avatar
2020 MB-AMG GLC43
Thanks very much!
Old 12-08-2016, 10:21 AM
Mike5215's Avatar
2016 C300
Old 12-08-2016, 11:06 PM
FastE's Avatar
2020 MB-AMG GLC43
It looks much better than their own pictures!?! I may buy it now - and I can use my existing phone portion
Old 12-11-2016, 06:19 AM
whiteC3002016's Avatar
2016 Mercedes C300
https://www.bhphotovideo.com/c/produ..._flexible.html
Old 12-11-2016, 03:28 PM
l3it3r's Avatar
2015 W205 C400 4Matic
I just use a Kenu XL
for some reason this is the only photo I can find right now.. lol It holds my iPhone 7 Plus in a case with ease, and can turn 360 degrees, and is easily removable (makes it great for the times you have a loaner or a rental)
Old 12-11-2016, 11:52 PM
FastE's Avatar
2020 MB-AMG GLC43
Where did you run the power wire? You seem to have it tucked away nicely.
Old 12-12-2016, 09:19 AM
Mike5215's Avatar
2016 C300
Along the inside of the bracket, then under the edge of the console back around to the rear of the console. It's exposed from the bottom edge of the rear console and then goes in between the console doors.
FastE (12-12-2016)
Old 12-12-2016, 09:35 AM
abstractls's Avatar
2015 C400 loaded
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I use this it works inside the cd drive as well as on the side of the dash in between where the led lights light up the dash
Old 12-12-2016, 11:39 AM
Mike5215's Avatar
2016 C300
I've looked at alternate mounts but none have a very elegant way to handle the cable, and I want to go direct from the device into COMAND via USB for audio (and charging). The ProClip's drop in mount with integrated lightning cable seems to work best.
FastE (12-12-2016)
Old 02-06-2017, 10:04 PM
FastE's Avatar
2020 MB-AMG GLC43
I am happy with the result of the ProClip. Worth the money easily because it looks good, holds the phone well, easy to push in for charging and can come off easily for resale. Nothing else seems to compare.
Old 02-06-2017, 10:55 PM
Mike5215's Avatar
2016 C300
Yeah, it doesn't get any cleaner than that.
Old 02-07-2017, 07:07 PM
NYbenzzz's Avatar
2016 C300
i have the proclip too.
honestly i would have preferred it to have it on the left side.
even with a iphone 7 plus, i can't make out the numbers while driving. phone seems too far.
i'm used to using the cd-slot loading holders, but it blocks my center console watch (which is the whole point of the center console in my opinion).
now a center vent mounted holder will block the command screen.
ahhhh choices choices
Old 02-08-2017, 06:13 PM
FastE's Avatar
2020 MB-AMG GLC43
I would have originally agreed, but there isn't a lot of space there. I don't think it would work for me on the left (perhaps because I have long legs?!)
Old 02-08-2017, 09:33 PM
B2FiNiTY's Avatar
'16 GLC300
I really like proclip products but in our case, it seems like it is too far away and is a big distraction if I need to even glance at it.
Old 02-08-2017, 09:40 PM
FastE's Avatar
2020 MB-AMG GLC43
I am all ears. At first I started this looking for other options but ended up back at ProClip. I would replace it if Infound something better. The vent clips and CD inserts are all useless with the console design.
I would like like to see something that holds the phone to the left of the screen?
Old 02-08-2017, 09:55 PM
Mike5215's Avatar
2016 C300
In addition to the cradle, if you want charging and the USB connection to COMAND you want something that doesn't have a visible cable dangling off it. The drop-in design with an integrated Lightning jack lets you connect the phone with one hand.
Old 05-16-2018, 12:07 PM
Rayc63s's Avatar
Bmw
Old 11-03-2018, 04:16 PM
Niko Belic's Avatar
2018 Mercedes c300 Cabitolet; 2013 Mercedes C250 sedan
Ultimate solution for Mercedes C-class W205
The final solution:
Car Phone Mount, APPS2Car...
https://www.amazon.com/dp/B07C265WKR?ref=yo_pop_ma_swf
Old 11-04-2018, 11:54 AM
Niko Belic's Avatar
Unltimate solution!!
Originally Posted by Niko Belic
The final solution:
Old 11-06-2018, 10:53 PM
Popoff's Avatar
2016 C300 4Matic Sport
This works well for me with my iPhone X
https://www.bestbuy.com/site/bracket...?skuId=5610800
Quick Reply: Phone Holders for C-Class
