Fan noise after Engine off.
Is it normal to have a fan? noise after you shutoff the car.
Its gone by the time I lock the door.
Just womdering.
"The engine compartment contains moving components. Certain components, such as
the radiator fan, may continue to run or start again suddenly when the ignition is off. There is a risk of injury.
If you need to do any work inside the engine compartment:
-switch off the ignition
-never reach into the area where there is a risk of danger from moving components,
such as the fan rotation area
-remove jewelry and watches
-keep items of clothing and hair, for example, away from moving parts"
