Rattle/Loose plastic noise from the back seat when turning...?
Old Dec 17, 2016 | 05:26 PM
alyshehata's Avatar
2016 C300 4MATIC
Hey guys,
I recently noticed that when making a sharp turn, I can hear something loose from the backseat moving around. If I make two sharp left turns, I only hear it once since I assume the loose object settles on one side, but once I turn the other side, it moves back and makes the noise again.
I checked under both front seats and there were some pens and stuff that I removed, but the noise is still there. I also opened the backseats downwards so I can check anything between it and the trunk and I didn't see anything. The noise sounds more like it is coming from "under" the backseat, but I haven't been able to have someone drive me while I sit in the backseat to figure out where exactly it's coming from. This noise started happening after a dealer visit to repair the door handle bulb, but I moved the door pretty fast and didn't hear anything loose inside so I'm not sure if thats related. Has anyone had something similar and have an idea for a fix?
Old Dec 18, 2016 | 02:57 PM
c300va's Avatar
C300
I'd recommend just going back to dealer to get issue resolved even though it might not be as convenient. Definitely easier for them to diagnose then on here.
Old Dec 18, 2016 | 11:42 PM
GrFa's Avatar
2015 C300 RWD
I had a similar noise and it ended up being the passengers front seat head rest. I swore it was coming from the back seat or rear door. Give the head rest a good thwap and see if its the noise you are hearing.
Old Dec 18, 2016 | 11:55 PM
alyshehata's Avatar
2016 C300 4MATIC
Thanks I just moved it around a little and will try it tomorrow to see if its fixed Posts like this suggestion was what I was looking for thanks for your advice.
