Screen Resolution
Just I make an upgrade to my c300h 2015 with the large 8.4" screen and I want to let every one know is not easy to do this upgrade but not impossible!Step 1, need to replaced and coding online on your vin nr the new ntg unit specific for that screen (8.4" one) because the old unit is set up with different resolution ,step 2,new rear camera for the cars have aready fitted by factory a camera plus again online coding for new camera,step 3 you need to install new software for satnav on the internal hdd what is fitted on the new ntg main unit(new unit is not anymore able to use the sd card with the maps)and step 4,need to coding online aswell the DAB module to the new ntg unit because after replacing the new unit the DAB radio is gone stop work until you coding and make compatible with the new ntg unit...Step 5 wich i find very stresfull ,for ntg unit the software is to big be able to coding online and install online and you need to order by Mercedes dealer 2 DVD (one with the ntg software and one with the regio maps, Make sure is from Europe or the region where you live )and make sure they will send out compatible with your vin nr otherwise is not gone work(me personal I order the software direct from Germany because in UK is was to expensive).My recommendation if you don't have a Star wich you can coding online by self or a friend, and save some money ,is possible to spend more money buying maps software and coding online then the all.cost for the parts need to exchange to make it work.If is anyone interested about any parts nr or different questions I'm happy to help!Thank you for attention!
I just replaced the 7 "screen of my 2018 GLC 250D 4 matic X253 with NTGS1 system, with a 8.4" one but it doesn't work, sometimes it turns on sometimes not, but the image is still 7 "in size as first and all moved to the left, can you help me in any way? thanks for what you can do for me.
