What Tire Pressure?
Old Jan 3, 2017 | 10:01 AM
jherm's Avatar
C63S
What Tire Pressure?
What tire pressure are you guys running with the run flats? I have the Continentals which are were set to 41/2 by the dealer which is in line with the door jamb sticker. But the ride is pretty stiff and am wondering if dropping a few psi is a good idea or if that will compromise handling too much and I know RFTs are supposed to be a little higher pressure.
Old Jan 3, 2017 | 10:04 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Look under the fuel filler door for the correct pressures. The ones on the door are for maximum loads.
Old Jan 3, 2017 | 12:49 PM
jherm's Avatar
C63S
It looks like the gas cap door gives a pretty big variance between front/rear on the lighter load guide (which is still 3 passengers + luggage). 42 in front and 33 in the rear. Does that seem right? Maybe I should do something like 38/36.
Old Jan 3, 2017 | 01:53 PM
StanNH's Avatar
I usually run 38 all around.
Old Jan 3, 2017 | 07:43 PM
Jawknee_5's Avatar
C400
I run 36 PSI all around for this unusually cold California weather.
