Door Control Unit: closing windows automatically
Mercedes C Class C180 W205 BlueTEC Executive 2015
I would to know please some technical documentations on the Door Control Unit Mercedes: technical specifications, their interfaces and modes of interaction with the other car's ECU (engine, telematics, etc.), the physical cabling etc.
I refer to a C Class registered in Italy for first time in April 2015 C180 BlueTEC Executive (W205 generation) with manual transmission; I would be able to enable automatic closing windows when I close the doors; this feature is not present thus the version is "Executive" and car has not "keyless go".
On eBay and AliExpress, I found several DCUs but with different Part Number from each other also depending on model and specification of the car generation.
Thanks to those who want to support me.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
It is not that simple first you need to subscribe to WIS, put your VIN in the system and select central locking system, then search the CL for door control modules---volia
'99 and '05 E55 AMG
