Suspension noise
C200 4matic
Suspension noise
My C200 has developed some slight suspension noise. Wife doesn't hear it but it drives me nuts.
The noise is particularly loud on very small bumps on the road, bigger dips I hear nothing.. I have checked my coils and accuair airbags and nothing is lose.
My installer did hear the noise also but couldn't identify the problem ( we didn't have time for a thorough check ).
Its a like a slight knock, not loud but its there. Has anyone on this forum experienced anything similar ?
Yup, I have a 2015 C400 and I was hearing the same type of noise. Went to the dealer they said everything was normal. Brought the car home a week later my car shows a malfunction sign and says car too low to drive. Had to have it towed to a dealer to find out my air suspension compressor went out. Apparently this was not common on a c class. The funny thing is that suspension rattle I had in my car I can also hear slightly in a brand new 2017 c300 loaner I'm driving.
C200 4matic
W205 C200 Sport Premium Plus. October 2018. 1497cc with 48 volt battery eq
My W205 with airmatic has this problem rear nearside only, been to dealer twice first time they changed the shock. 2nd time they said they had contacted MB in Germany who said it was a known problem and were working on a fix, said though it was safe to drive.
C200 4matic
I just cant figure out if its really from the suspension or maybe the steering column thats hitting something.. its a not a loud metallic knock so it confuses me.
I've owned 3 AirMatic cars and at some point each had either a strut and/or compressor failure. (Usually a leaking strut causes the compressor to run continuously trying to maintain pressure and it burns out). None failed until at least 60k miles. Odd that these are going already.
C200 4matic
Besides I only have 5000 miles on the car. I think its more related to a new car baby disease issue
That is very interesting thank you.. I think ill drop by car at my tuner soon to have them double check. The funny thing is that its not a loud noise it just drives me crazy cause I know it shouldn't be there.
i have the similar problem
To sum it up.. make your mercedes benz mechanic to dissambly the suspension, and check suspension tension / hydraulic tension, in my case the rear left suspension was weaken and have a different tension with the rear right suspension.. it's covered by warranty to be replace (800 USD for the parts, but its free) .. After that.. no more noise..
Hope it helps..
