C400 Back from Dinan...
Old 05-22-2017, 01:24 PM
  #426
BRBM's Avatar
2016 C450
Originally Posted by CFG
The hardest part is getting your hand in a tight space to remove a connector. If you need help, drop me a pm and I'll talk you through it.
Thanks a bunch; may need to do so. Took a look under the hood Saturday, and quite frankly the thought 'kinda tight down there; will have think about navigating this step 'fore I order' did cross my mind.
Who knew?
Old 05-22-2017, 01:32 PM
  #427
Former Member
removedCFGaccount's Avatar
CLS
The connector is a little tricky, but easily removed once loose. If you can find a woman or a 12 year old to do it, it will be a snap.
It is really very easy.
Old 05-22-2017, 01:40 PM
  #428
russAMG's Avatar
GT C coupe
Is anyone looking to sell their DINAN?
Old 05-22-2017, 01:52 PM
  #429
Former Member
CLS
Russ, as hard as some of us were on it, I suspect not. It is nice to have that little something extra available.
russAMG (05-22-2017)
Old 05-22-2017, 09:09 PM
  #430
Mr. J's Avatar
C450, GLC43
I used a small flathead screwdriver to loosen the clip. Just be careful not to damage it.
Old 05-22-2017, 09:13 PM
  #431
Former Member
CLS
As I recall, the sensor clip has a small tab on top, that you push down. Is that right?
That's great advice: I'd hate to think of the replacement costs....
Old 05-22-2017, 09:19 PM
  #432
Mr. J's Avatar
C450, GLC43
That tab actually slides. That's what I needed the little screwdriver for. My fingernails were too short to grab the little *******
Old 05-22-2017, 09:21 PM
  #433
Former Member
CLS
O.K., so, you need a midget, with a small widget, to slide a small tab....
  #434
Mr. J's Avatar
C450, GLC43
Once my GLC43 is broken in, I'm going to swap the Dinan over to it. I'll try to take some pics when I do.
Old 05-23-2017, 07:00 AM
  #435
MASSC450's Avatar
2016 C450 AMG
Incorrect, it slides back.
A long screw driver with a small blade inserted between the white locking portion (which slides back when unlocked) and the black portion of the connector itself...then a slight twist...and you can feel the "click" once the white lock portion is unlocked.
Then you can pull out the connector from the intake pressure sensor.
Old 05-23-2017, 07:31 AM
  #436
Former Member
CLS
Mass...
Hello...hello....hello.....
Well, you can never be too careful....but a sharper photo would likely help.
Old 05-28-2017, 01:41 PM
  #437
russAMG's Avatar
GT C coupe
Im guessing the dinan woun't make a noticeable difference in 0-60 times.
Just watched this
stock c43 with 367 HP/520NM vs tuned c43 434HP/643NM
Old 05-30-2017, 07:52 AM
  #438
BRBM's Avatar
2016 C450
Just watched this https://www.youtube.com/watch?v=GA7Nv7UjtZE
Maybe a little, Russ. Thinking some of those who've done it can give us the lowdown.
In other words, if we're getting 40/40 and considering RennTech's dyno rated us @ 375/398, that takes us to roughly 415/440..........nothing to sneeze at.
So when also considering the 4-matic's grip, I hazard a guess that the extra is noticeable, and while probably not anything mind-blowing, probably something our butts will DEFINITELY feel. And like. In fact, if memory serves, someone here has posted we get some serious extra oomph in the mid-range, already a strong suit. Go-to-jail speeds come quickly in stock tune.
Better still, I've done basic upgrades on other vehicles that added about 15-20% more HP (30-40 something) via SLP or equivalent Cold Air Intakes, K&N hi flow filters, Flowmaster 40 series muffler upgrades. I felt that, so I'm optimistic.
Old 06-20-2017, 12:21 PM
  #439
subzero05's Avatar
CL500
good post/read here from a dinan sport user with a C450
http://c450amg.com/product-review/20...formance-tuner
Old 06-20-2017, 04:04 PM
  #440
Former Member
CLS
Yup, deja vu all over again, but nice to have some objective data.
Old 06-20-2017, 06:37 PM
  #441
Darrington's Avatar
2015 C400
Thanks for the link...good stuff. The guy put the Dinan unit on top of an already tuned car...and made even more power, love it!
First time I've read about the limp mode / check engine light issue...something to watch for I guess.
Old 06-22-2017, 07:16 AM
  #442
l3it3r's Avatar
2015 W205 C400 4Matic
I've run my Dinan in Race mode pretty much since the day I got mine (I think I got it in the first batch after the 'trial' they did with a couple/few people). It has been fantastic, and the car runs like a scalded dog now. I think I'm going to get the OE tune next. Just need to figure out this wheel/brake wobble.. wtf
Old 06-22-2017, 02:06 PM
  #443
l3gendary's Avatar
C300 sedan
I'll be getting it for the c300 soon will report back to folks here
Old 06-25-2017, 08:57 AM
  #444
Darrington's Avatar
2015 C400
I had mine back in stock mode for a few days (was in race since I installed it), just to see the difference going back the other way to stock. Bone stock seems slow now!
Old 06-25-2017, 10:23 AM
  #445
Mike5215's Avatar
2016 C300
I have the C300 unit. It's a modest change but I like it. Worth the money IMO. I typically have it at +3 PSI. There's also a Valet mode that reduces boost to -6. Handy if you have a teen driver.
Old 06-25-2017, 01:49 PM
  #446
subzero05's Avatar
CL500
Yep I keep mine in sport + all the time now with 91 octane . Went back to stock and said NO!! I like my new found power and been tha way ever since . Definitely worth it IMO as well
Old 07-04-2017, 02:05 PM
  #447
Randy Toro's Avatar
c-class 300 w205
Originally Posted by Waynezworld
Ok as some of you know, my C400 was down at Dinan Motors getting a chip, here are the results...
hi I bought one for my c-class 300 sport 2.0 and installed it and I have it set to tace mode but I don't know if I can feel the difference. There still lag at the start when taking off. I wonder if I uninstall it and see if there's a difference. Is your car the 6 with twin turbos?
Old 07-05-2017, 02:38 PM
  #448
subzero05's Avatar
CL500
the turbo 4 Dinan sport is good for about 20 HP and 20+ torque. Not quite as robust as the Dyno posted above on the 3.0L , but still a decent bit of power for $299
Old 07-06-2017, 02:27 PM
  #449
subzero05's Avatar
CL500
FYI all- I got an email from one of the guys over at Dinan today . They are ready to develop an ELITE tuning solution for the 400,450,C43 variants and need a car as early as next week!. just passing this along so if there is anyone in the bar area who is interested send them an email to developmentcars@dinancars.com
Old 07-06-2017, 02:38 PM
  #450
Former Member
CLS
Well, I can't give em a car, but I can say I'm in!
