Changed grille to C63 grille
Old Apr 17, 2017 | 07:03 AM
Harrier's Avatar
C220d
I've been trying to swap my standrad grille over but been confused by the confusing PDF instructions.
Most is OK and I've made my way round the lasck of info but I'm stuck on removing the front splash shield.
I have a fixed bracket at the back of the front splash guard which isnt easily removed ?
I've circled it in the picture below,
Msytery clamp Ptr No. A 213 628 12 00
I've also got a picture under the car to show it in more detail,
Any advise from those who have made the grille swap as to how to remove this clamp ? ... it doesnt seem obvious to remove to me.
Thanks all,
Old Apr 17, 2017 | 07:20 AM
christyan78's Avatar
C 180 w205
I didn't find that clamp on mine.Shield is secured only with bolts.There's 4 bolts holding the 2 shields on top of each other.
Old Apr 17, 2017 | 07:30 AM
Harrier's Avatar
C220d
Bummer ... perhaps its a year/model thingy
2017 W205 C-Class 220d 4Matic
I'll have to ask the dealer ... which I was trying to avoid as they warned me off changing the grille or comprimising my warranty.
Old Apr 17, 2017 | 07:34 AM
C 180 w205
Did you remove all the other bolts and the shield doesn't drop down?
Old Apr 17, 2017 | 07:41 AM
Harrier's Avatar
C220d
Took 9 bolts out the front shield in total, and it moves about an inch forward into the lower spoiler recess .... but the clamp holds it captive and I can't remove it.
Old Apr 17, 2017 | 07:45 AM
C 180 w205
When i took mine out i had to remove the second metalic shield in order to take out the plastic shield.Maybe it will be better if you do the same.
I lost more time trying to cut corners and trying to push in the plastic shield without droping the metal shield first.In the end i removed both.
Old Apr 17, 2017 | 07:52 AM
  #32
Harrier's Avatar
C220d
Must be a year/model thing as I don't have a metal shield. I have what's on the w205 how to remove splash shield layout.
I have a ribbed front plastic shield and then a mid car positioned plastic shield, but the clamp in my pictures hold both in place. I could wrestle the front shield out past the mid position shield if the clamp could be removed.
I don't have access to an EPC ... anyone got a diagram of that part would be helpful to see if it's sprung loaded or just bolted in behind a plastic cap or something.
Old Apr 17, 2017 | 07:58 AM
  #33
C 180 w205
On mine the mid shield is metal and is sitting on top of the plastic one so i had to drop it first.
Same as this..
Old Apr 17, 2017 | 03:48 PM
  #34
789's Avatar
789
I did mine a year ago at night by myself; not sure my memory still correct or not.
If I recall correctly, that "clamp" is just let the shield slides in place properly. Once all the bolts on the front and mid shield are removed, you just need to slide the front shield forward to drop it. I guess you didn't slide it forward enough to drop it.
Hope it helps!
Old Apr 17, 2017 | 03:54 PM
  #35
Harrier's Avatar
C220d
Hope it helps!
I could try again this weekend with a bit more force ... did you disconnect your battery before removing the plug and bumper?
Old Apr 17, 2017 | 04:19 PM
  #36
789's Avatar
789
No, I didn't disconnect the battery.
Old Jul 13, 2017 | 09:53 AM
  #37
Pker's Avatar
Originally Posted by speed608
First Mod after purchase.
Looks nice! Is it the authentic c63 grill or the ones from eBay? Looks much more manly
Old Jul 13, 2017 | 10:42 AM
  #38
speed608's Avatar
C Class W205 and BMW F30
Got it from a company in the U.K.
Very good fitment.
Old Jul 17, 2017 | 12:37 PM
  #39
medkm's Avatar
Mecedes E 220 c238
Old Jul 17, 2017 | 12:40 PM
  #40
C 180 w205
Where did you get the front lip from?
Old Jul 17, 2017 | 12:49 PM
  #41
medkm's Avatar
Mecedes E 220 c238
http://www.ebay.com/itm/Piecha-Front...AAAOSwX~dWjKEG
