MAF, MAP, and O2
Old Mar 8, 2017 | 04:03 PM
peterherz's Avatar
2012 C250
MAF, MAP, and O2
Just hooked up Torque to a bluetooth OBDII and am getting some new info about my C250. One is that only one of my two (?) O2s in bank 1 is giving voltage.
and MAF gives nothing (no volts) but isn't setting any codes as faulty. Not getting any codes except a cylinder one fixed by replacing a coil and plugs.
Getting one code though that won't disappear relating to crankshaft position but pretty sure my questions aren't related to that.
Question is does the C250 have a MAF? Or just a MAP? Also could one of my O2s be failing due to failing MAF or is it failing regardless?
Old Mar 8, 2017 | 05:30 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Mine has done the same, ie no second O2, no MAF etc.....
Don't discount its a software issue in the app..
My car runs fine, no codes (flagged or stored), no issues..
Old Mar 8, 2017 | 05:43 PM
peterherz's Avatar
2012 C250
Well that's reassuring there's videos on how to test it manually just seemed like small hassle.
