12V power Tap for Sub Amp
Can anyone please assist with where the best place to get power for an amp that will be mounted in the boot will be .I normally tap power directly from the battery don't really want to run a cable all the way from the front and don't even know if it is possible to run a 4 gauge cable through the firewall.
Also looked at the SAM/ Fuse box and there is a 4 Guage power cable that is feeding power to the module which would be ideal, but I don't know if it's safe to connect the power to that instead .
Any help will be appreciated.
How much current are you expecting the sub & amp to draw at peak?
Slightly off topic, so I installed my amps for the door speakers and a mono block for the sub.Anyway I have a slight engine whine off the door speakers I have tried earthing at different positions and the amp is installed next to the front footwell woofer and is powered of the factory head. The amp I have used is the BLAM RA 704 RT with DSP.
Any assistance will be appreciated.
