BOV question, GFB vs Agency Power vs TurbotKits
question regards to the BOV adapter for our W205s.
I noticed that the BOV from C250, C300, C400, C450, C43, C63 are all the same and I begin to search to see if it a common parts that is used in modern cars.
From the TurboKits,com I found that Mini Cooper S also uses similar style BOV adapter.
http://www.turbokits.com/Mini/Cooper..._Adaptor/2457/
I also then compare the TurboKits.com style and Agency Power style
https://www.agency-power.com/shop/ag...300-c400-c450/
and found them quite similar, it is more of a spacer rather than a BOV that draws open air into the turbo's circulation .
Then I think back to the GFB style BOV for the W205 and found that they are a true BOV rather than a spacer.
http://www.gfb.com.au/products/blow-...d-volvo-detail
My two questions then is,
Will the Mini Cooper S / Ford / Volvo BOV fit in our W205s?
gain from true BOV(GFB style) vs BOV Spacer~
Any inputs are appreciated. Correct me if I am wrong at them.
Thanks!!
Thanks!!
Here is the link: http://www.gfb.com.au/products/blow-...d-volvo-detail
I would recommend buying it direct from GFB, as there are many knock-offs in ebay. the price is pretty much fixed, so if you see one which cost much cheaper, it's probably a replica!
Anyway, just to make it clear, i am not a seller and do not earn anything from GFB.
I am using their product and just simply happy with it and want to share.
