Corrosion on engine cover
Old May 6, 2017 | 08:19 AM
Humvee21's Avatar
'16 C300
I noticed some corrosion on the engine cover. Then I removed the plastics over the engine and found even more. Is this normal?
Attached Thumbnails Corrosion on engine cover-img_20170505_171302.jpg   Corrosion on engine cover-img_20170505_171308.jpg
Old May 6, 2017 | 08:24 AM
MASSC450's Avatar
2026 GLE 53 Coupe
Yes, it's normal if the material is aluminum...which I believe most of the engine is made of.
Aluminum is prone to corrosion. Keep in mind though aluminum corrosion is aluminum oxide, a very hard material that actually protects the aluminum from further corrosion.
