Adding subwoofer to burmester
It would be amazing if someone can giving us the wiring diagram/installation pictures for the burmester amp in the trunk. I'm sure this is the only think holding most of us back from installing it.
I've found the attached wiring diagram, but I cannot make any sense of it (I cant even find this connector on the amp LOL)
Buy a line output converter. Best Buy carries them for under $20. This was actually the easy part!! The hard part is running your power cable for the amp. The power cable should be ran to the battery so unless you have a MB that has a battery located in the trunk then get ready for some serious work. You can theoretically tap into the fuse box in the trunk for power if you are running a really small amplifier but I do not recommend this. Remeber to keep your ground for the amplifier as short as possible. You can tap into the fuse box located in the trunk to run your REM, which will power the amp on and off. Just locate a fuse that opens when the key is turned to the acc/on position.
Hope this helps and sorry if I got to basic with it but honestly if you don't have a lot of experience installing car audio then spend $200 for a year membership in the GEEK SQUAD and they will install everything for free. All you have to do is supply the equipment.
Good luck!!
