Infotainment touch screen
Old May 14, 2017 | 08:18 PM
don w's Avatar
C300 W205
Just watched a YouTube demo video on the 2015 C300 Infotainment system (I have a 2016 C300) and it had a touch screen that functioned in the demo video. Should my 2016 have a touch screen ?
I have Comand with the 8.4 inch screen?
Old May 14, 2017 | 08:41 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
No
Old May 14, 2017 | 11:39 PM
carjr's Avatar
SLK
You probably watched an after market one. Mercedes doesn't make touch screen.
Old May 15, 2017 | 01:56 PM
nobbyv's Avatar
2016 Cardinal Red AMG C63 S
Not in the C-class, it doesn't. The E-class has one.
Old May 15, 2017 | 02:04 PM
DapperStyle's Avatar
2014 C300
There are no touch screen Mercedes, not even the E.
Old May 15, 2017 | 02:30 PM
nobbyv's Avatar
I'm seeing conflicting info on this: this R&T review specifically mentions a touchscreen:
http://www.roadandtrack.com/new-cars...s-first-drive/
Inside, the traditional gauge dashboard can be replaced with an optional flat-panel digital setup using side-by-side 12.3-inch displays for the driver's instruments and the center-stack touchscreen.
And a number of different dealers mentions one:
https://www.mbofhenderson.com/new-ve...d-information/
The elegant interior of the Mercedes-Benz E-Class wows with hand-fitted leather upholstery, and a choice of hand-polished wood trims. The Nappa leather multi-function steering-wheel and COMAND® system with a 7-inch touchscreen and central controller both provide quick access to Bluetooth®* and audio controls.
But I think you're actually right, as MB doesn't mention it on the website.
I actually looked at it at the NYIAS this year, but can't recall for sure if I tested that.
Old May 15, 2017 | 06:04 PM
2014 C300
I've sat in multiple Es with the Digital Dash and it's definitely not touch. Instead it has two touch pads located on the steering wheel. R&T is completely wrong.
MB concepts have hinted at them maybe adding a small touch screen but it will be located much lower:
