AerowerkZ 360° Surround View System for W205 C-Class Sedans
Former Vendor of MBWorld
AerowerkZ Motorsport is proud to announce 360° surround view system for W205 C-Class sedans.
Attachment 442081
A small hole needs to be drilled to mount the front camera.
For those with luxury or Distronic grille, we also have universal front camera that is mounted on flat surface.
Attachment 442082
Attachment 442083
Entire plastic cover with integrated camera for side mirrors is included.
Attachment 442084
Attachment 442061
On some models, only the cover needs to be replaced with camera (Above shown for C-Class and GLC-Class)
Attachment 442085
Entire trunk handle with integrated camera is included.
Factory backup camera and handle need to be removed.
Installation
Attachment 442086
360 box - Factory display cable connects to the box and box's display cable connects to the display unit
Attachment 442087
Display unit, air vents and head unit need to be removed for installation.
4 camera cables connect to our 360 box.
Attachment 442088
Calibration mat included.
Install Guide (PDF)
- Automatic surround and rear views in split screen when in reverse
- 4 cameras and wiring harness included
- Live view while in-motion
- Video recording (USB flash drive is not included)
- Comes with 1-year warranty
- Price:
$1,299$999 (limited time offer) - FREE shipping to continental US for forum members
- No cutting of factory wiring harness
- Professional installation is strongly recommended
- Plug & Play; no version coding is needed
- Optional offline navigation map (SD card)
Attachment 442081
Attachment 442082
Attachment 442083
Attachment 442084
Attachment 442061
Attachment 442085
Installation
Attachment 442086
Attachment 442087
Attachment 442088
Install Guide (PDF)
So if you currently have rear camera must you still remove and use "your" handle and camera or will it integrate in. Also if you do have rear camera currently is the box still required to be added or are there connections on the factory box that your cameras can be plugged into?
