Backup camera stopped working
Old Aug 4, 2017 | 12:33 PM
NewMBC300's Avatar
2015 C300, 2012 Odyssey Touring Elite
My backup camera stopped working. It was working few minutes back at the shopping mall. The display does not change when I put the reverse gear. The camera is not opening. I checked the system settings and the option activate rear view camera is checked. Any idea?
Old Aug 4, 2017 | 02:40 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Run your finger under the trunk lip and see if there is any obstruction. If you find none, call the dealer and schedule a visit.
Old Aug 4, 2017 | 05:37 PM
NewMBC300's Avatar
Mikey, I am able to open the camera under the system settings and no obstruction under the lid lip. So no obstruction. Will call dealer.
Old Aug 4, 2017 | 11:31 PM
Greg52's Avatar
W205 C250
Mine had the same fault but intermittently. Worked fine all winter but in summer here in Australia it would often stick after driving a short time. The dealer did not really help much because they could not reproduce the fault, it took several service visits and finally a video to prove the fault existed. They replaced the camera but its still winter here so I am not sure if its fixed but live in hope
Old Aug 7, 2017 | 07:59 AM
NewMBC300's Avatar
Thanks for the info. I scheduled an appointment this Friday. Let's see what they tell.
I am able to open/closet camera from the system settings. But it does not open when I shift to reverse gear. Hoping some malfunction with camera and covered under warranty . Just last month I spent 1k on the door. Not in a position to spend any more money.
Old Aug 14, 2018 | 09:47 AM
grzegorzgaj's Avatar
C-Class C200 W205
Hey, what was the problem with your camera ? Was any part replaced (Comand Online, Camera Module etc) ? I'm having same issue in my W205. The dealer replaced the whole camera module to new one but it is still not working. The power is fine, signal is fine, only controller is not able to use the camera.
Old Mar 22, 2019 | 01:14 PM
Byron kent's Avatar
W205 Estate
Did anyone find out a fix for this?
I have the same issue. have taken it to my local dealer but they have been absolutely no use.
Any ideas would be greatly appreciated!
Old Mar 22, 2019 | 01:34 PM
C-Class C200 W205
hey Byron. In my case dealer eventually fixed the camera. The thing was that the new module didn’t want to talk with the controller. They had to ask some engineer from HQ who remotely connected to my car and have “programmed-in” the new camera module. From the Comand Online I could tell the field of view is a little different than before so I guess if a dealer receives a spare part, even tough it has the same part number it is a different module and controller not necessarily wants to talk to it unless manually programmmed.
Hope this will help.
Greg
Old Apr 18, 2019 | 10:38 PM
Michael Rott's Avatar
2019 E450 Cabriolet
Backup camera stopped working. 2016 C300 is still under warranty. MBUSA covered cost of part but dealer charged for labor claiming the license plate frame I installed was a hair thicker than the dealer frame they installed and that was causing the camera flap not to open properly. Has anyone heard of this? I see college alumni license plate frames on hundreds of cars!
Old Apr 19, 2019 | 12:04 AM
Rogue-CLK's Avatar
2016 C300 4Matic
Happened to me, I just gently tapped my camera and all is good, probably loose connection.
Old May 13, 2019 | 02:24 AM
AlexRo's Avatar
Mercedes C300 coupe 2016
My reverse camera did not come out from under the lid for the last 2 months. This morning i noticed when i went in the parking lot the the camera is out. Now it doesn't go in. Week in week out this car visits the garage for different problems. It is by far the worst car i have ever encountered. Camera, sensors, inside display, collision brake assistance...you name it...
i regret i sold my Honda...
Old May 13, 2019 | 08:12 AM
Greg52's Avatar
W205 C250
Sort of miss my Honda too
Old Jan 16, 2020 | 10:44 AM
STRIPKWIK's Avatar
C220 W205
I have put my car for service. After software update it deleted the bit where it recognises the reverse gear! 5 min fix!
Old Mar 1, 2020 | 03:25 PM
charmz's Avatar
C300
My camera stopped working today out of the blue.
When going into the system settings menu I can manually open the camera for cleaning but the camera will not open when putting car in reverse.
Owned the car for less then a year and seems to have never ending problems... gas door malfunction, wrist pin issue, oil level sensor, front axles, climate control unit and now backup camera.
Star Certified Lemon
Old Jun 11, 2020 | 02:53 PM
charmz's Avatar
C300
So, I dont know what it is, but all of a sudden when the hot weather has come and the camera started working 100% of the time.
In the winter, would work less then 50% of the time.
How/Why would the temperature affect a camera?
Any ideas?
Old Jun 11, 2020 | 04:05 PM
chrisdean's Avatar
W205 C200 AMG Line Premium
Check the wiring loom around the trunk hinge, remove the black plastic cover and check for broken wires. There is not enough slack in the loom and wires snap. Check here also for faults to number plate lights and boot/trunk not opening. If your problem is heat related, remember metal (copper) will contract in the winter and expand in the summer. I found 4 broken wires in my loom.
Old Jun 11, 2020 | 06:17 PM
places's Avatar
No more MB:(
You will need to take it to the dealer.
Old Oct 5, 2020 | 05:01 PM
Simon.ari's Avatar
W447
Solved
So guys I had this very same issue with the rear camera that would not open, and I thought very hard about this and managed to get it to work again. My thinking was the rear camera was not being triggered when placed in reverse, so I reset the gearbox and this in turn reset the trigger for the reverse and then the camera worked.
Old Oct 8, 2020 | 10:36 PM
wewong's Avatar
18 C300 Wagon
Just noticed a weird behaviour today when driving my car. Whenever I slowed down to less than 20 km/h, the camera would pop out. When I speed up pass 20 km/h, it retracts. Happens when the car is in drive. When put into park, the camera retracts.
Old Oct 9, 2020 | 08:07 AM
chrisdean's Avatar
I think it's self-calibrating.
Old Feb 15, 2021 | 10:00 PM
Shann's Avatar
Mercedes c220
Hi,
can you please tell me how you sorted this out as I have the same problem after my car had diesel update.
Old Jan 1, 2022 | 04:50 PM
MartyRL's Avatar
GL350
What was the 5 min fix?
Old Feb 22, 2022 | 03:44 PM
simonsellick's Avatar
C350e
Reversing camera
How do you reset the gearbox?
Old Aug 10, 2022 | 12:41 PM
05-E55's Avatar
2005 E55 AMG
Genius! Thank you. Worked for my W166
Old Sep 4, 2024 | 03:37 PM
Smasher@3's Avatar
C 300
My 2016 C 300 back up camera stopped working suddenly, Any solutions ? the dealer is asking 200$ for Inspection.. Please Advice
