C300 Turbo Upgrade - Partner Needed
#276
C300 almost done with the tuning !
BIG thanks to Jesse at turbo kits and AMR tuning
https://www.instagram.com/p/BrOLmU6I...d=94dmsoatd0w0
#277
TurboKits.com (12-14-2018)
#280
i still waiting for the time to do dyno test and maybe some retune again
in Indonesia it's very less workshop with dyno
#282
C300 turbo
So the tuning has turned out to be a bit more challenging than initially expected..the ecu of these vehicles are very complex..the final tuning is going to be tackled mid January..so hopefully we’ll have some final numbers soon
#283
2016 C300 base model w205
#284
Future design
I originally had 235”s up front and 265”s out back but after lowering the car I had to go to 235”s all around because of the offset of the wheels..my tires are right at the edge of the fenders
#285
Wheels
If I change my wheels again I’m going to 265”s out back again
but as you can see here there’s just no room to go wider due to the fenders and offset
Heres my newest addition to the car
Custom carbon wheel
#286
the spoiler is from future design ..all the carbon parts on the car came from future
Future design
this is what my car currently sounds like without the mufflers and primary resonator: when shifting with the paddle shifters I sometimes get a loud backfire but it’s not quite as consistent as I’d like it to be. Possibly open down pipe?
#287
Tires
you can actually fit 275”s under the stock suspension with the proper offset ..265”s are no problem
the c63’s come stock with 265”s out back and the c63’ is the same as our c300
if you want the consistent “burble” or fire it’s really about the tune
take it to a good tuner like amr and they can load a fire breathing tune into it with the exhaust you have
Catless downpipe would help but I don’t think you’d really need it
wait til you see some of the fire breathing pics of my c300 that were captured while it was on the dyno
everything will I’ll be posted once the tune is done
#288
C300AWD (01-21-2019)
#290
C300
I actually JUST dropped my c300 off at AMR again today for what I hope is the final tune
they think they have the mapping figured out so we should be able to get a solid high boost tune on it
if all goes well I’m hoping to get it back by Friday this week!
fingers crossed
in the meantime ..check out this bad boy ..900whp c63s they’re tuning up at AMR
fingers crossed
#292
Meth kit
from what I understand the meth is really used to lower the intake charge/temps ..with the stock 12lbs it wouldn’t give you anything
my meth is tuned to inject at around 12-13lbs +
This big turbo upgrade by turbokits is making 25+lbs of boost in my c300
#293
fingers crossed
fingers crossed
#294
fingers crossed
fingers crossed
mine is also got delayed because must tune it again after the meth installation correctly
will do dyno run again in near future
#296
#297
Starting the same here, ordering turbo upgrades, snow meth kit, and burger air intake from Jesse for my C450AMG then ship to AMR. Currently have AMR’s stage2, weistec DP’s, awe track exhaust. Wanted to ask if you had any thoughts or suggestions on how your project went so far with relation to needing other internal engine upgrades to compensate for the higher boost levels?
Again congratulations to you all, and thanks for leading the way!
The following 2 users liked this post by Hrd_workin:
DIVINE AMG (01-28-2019),
TurboKits.com (01-28-2019)
#298
C300
Aj, been following this thread for awhile. My compliments and congrats to you on your project.
AMR has been great as well as Jesse ..your 450 is going to be a rocket ship!
AMR really knows what they’re doing and can see any signs of internal motor stress or Malfunction while tuning ..so I wouldn’t worry about the internals for now. Rob at AMR mentioned that they’ve been able to make some pretty killer output from the platform you’re starting with.
I also have a 2015 Jeep SRT that I just had a new turbo motor installed into..it’s not quite done yet but when I get it back I’ll be bringing it to AMR for some fine tuning!
The following 2 users liked this post by Ajagielski:
#299
That is great to hear AJ. Thanks and I look forward to working with them as well. Once you get those final dyno numbers, I am sure everyone is eager to see those, don't forget to post please :-)
Best regards
Best regards
The following 3 users liked this post by Hrd_workin:
