Closing in on deal for '15 C300. Wrist Pin issues?
Just bother the living **** out of mercedes until everything is fixed!
Engine number is 274920 E0 024143.
Also the engine had 32000 when I bought it and I've put on about 1000 miles. Did have to take it in to the dealer for a power train program upgrade but that was the only recall or issue they found for my car.
I did some research here before buying the car and asked the dealership to check to ensure it was not affected by the popular wrist pin issue or asked if it had already been repaired.
It had not been repaired and assured me it was not affected, but my car sounds like this when cold.
Engine # 274920 E0 016710
(Outside mounted camera - Listen at 0:45 and 0:53)
(Camera from car interior - Showing tachometer)
https://vimeo.com/333172704
https://vimeo.com/333173227
Anything I should know about or look for when the car is returned?
This seems to be a less known about issue up in Canada.
Anyone in Canada?
Just got my car back today, will have to see when its cold if the noise is now gone.
1 274-037-03-00 TS PISTON
Is this a kit or an individual piston?
Being a 2015 model, I am concerned about the wrist pins. It was mechanically inspected and does not have any of the noises associated with wrist pin issues. I was on vacation in Seattle when I found it so I heard and saw the car in person.
Anyway, I ran the vin on a few websites that show the delivery date(?) of April 29th, 2015, and I know that some engines before April 20th are affected. Is there a way a know for sure if this vehicle is affected by the wrist pin issue? The VIN is listed below if anyone wants to run it to see. Like I said, I'm a BMW guy so this is my first dive into the world of MB.
55SWF4JB0FU070722
can you please tell me if my car is a part of the wrist pin issue run? Or does it have the good parts? Thanks in advance. Newbie here. 55SWF4KB7FU070036 my vin
Engine no.:
274920 E0 042176
According to an official response from Mercedes (TSB: https://static.nhtsa.gov/odi/tsbs/20...36088-9999.pdf)
Modified wrist pins are installed as of engines:
274920 E0 043259
Sorry to tell you but your engine falls under a possible wrist pin issue
There was a manufacturing run of wrist pins that were not tight enough tolerance. When compared with pistons/rods that also can be on the high side of tolerance, you can get excessive clearances and a rattle noise until they warm up slightly. That's it. The repair kit is new complete piston/rod assemblies, rings and all.
It's not a "design" defect, as the design didn't change. The supplier (mercedes doesn't build the parts in house) was sending parts with just a little too much tolerance, it was found out and corrected after a certain point. Any engine before then, if it has the noise, will get a new piston kit. There is no engine wear, cylinder damage, etc. It's not a quick replacement but it's fairly simple, takes about 2 days for an experienced tech assuming the parts are available, little more on a 4-matic car as there's more in the way to remove the engine.
Don't try to scare people because you don't understand what's going on and are afraid.
