Key Fob Upgrade
Otherwise you cannot start the car when your battery is dead.
why would they expose themselves to frivolous lawsuits ? it would be silly cause that's what people do , not you but other people.
The old key failsafe start uses the IR window in the "snout" to verify the key. The new key uses an NFC chip and the NFC reader in the dash tray. (NFC gets it power from the reader inductively, which is how it works with a dead key battery.) Furthermore, if you have Keyless Go the new key has an accelerometer that puts it to sleep if it's sitting. This is for security so thieves can't clone it if it's sitting in your car in your garage. It also improves key battery life.
But if you start the car with a sleeping key sitting in the car, it will wake it up by RF or NFC if its battery is dead. All very cool, but none of that can work with a modified key in an older model. Pure poseur.
https://benz-yourself.com/products/s...es-benz-models
Not sure if this is legit, but I have multiple keys...
