2016 C450 top speed limiter
Old Oct 19, 2017 | 05:43 AM
VFORCE09's Avatar
2023 C63s Coupe, 2020 CLA 45,2018 C63 Coupe,2016 C43,2014 CLA45,2013 C350 Coupe,
Question 2016 C450 top speed limiter
Hi all
I have and issue with my 2016 C450
For first time in two years of having the car i was able to go to the track and test the vehicle and to my surprise the top speed limiter kick in at 130 mph at 4000 rpms
now this is a concern to me when Mercedes advertised the top speed was limited to be 155 MPH, has any body with a C450 has had this issue
please let me know
Regards
Old Oct 19, 2017 | 06:43 AM
l3it3r's Avatar
Veteran: Army
2015 W205 C400 4Matic
limited because of the tires the car came with.
get a flash on your ECU for $1200 and that limiter is removed - but make sure your tires are up to the task.
Old Oct 19, 2017 | 08:16 AM
removedCFGaccount's Avatar
Former Member
CLS
Originally Posted by VFORCE09
Hi all
please let me know
Regards
if you have conti runflats, may I ask the pressures you use? Thanks
Old Oct 19, 2017 | 08:46 AM
VFORCE09's Avatar
I have 19" AMG wheels with run flats from the factory
Old Oct 19, 2017 | 08:47 AM
VFORCE09's Avatar
I have 19" AMG wheels with runflats from the factory
36 front and 34 rear
Old Oct 19, 2017 | 10:21 PM
GerritKw's Avatar
C350e
There is a speed limit that you can set for the (winter) tires on the settings menu.
Maybe that is set to a certain value. But usually you get a warning when you hit that limit.
