2015 C300 removing panel switch window
Old Oct 21, 2017 | 10:46 PM
r_kelly's Avatar
2015 c300 mercedes
Hi
I would like to remove the driver panel switch windows on my mercedes 2015 c300 to replace it, I have 3 button broken. is there anyone who has a tutorial how to disassemble this panel. I bought a panel switch on web but I do not know how to install it. I found web videos but for olders models of mercedes. Thank you for your answers
Old Oct 22, 2017 | 06:18 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Unless there are screws holding just the armrest on (which looking at mine visibly there aren’t), you may need to remove the door card.
Old Oct 22, 2017 | 08:26 PM
r_kelly's Avatar
2015 c300 mercedes
thank you for your answer. but I thought it's just the old mercedes model that we had to remove the door card. I dont know if it is possible to remove only the armrest. would anyone have an idea. thank you
Old Oct 22, 2017 | 09:46 PM
fabbrisd1's Avatar
A gaggle of MB's
Door panel is one piece - and YES it has to come off
Old Oct 22, 2017 | 10:32 PM
ItalianJoe1's Avatar
2003 CL 600
Two screws and the door panel pops off, not a big deal. The switch has to be removed from the inside, no other way around it.
Old Oct 26, 2017 | 02:57 PM
r_kelly's Avatar
2015 c300 mercedes
I removed the door panel but I dont see the access how to remove the window panel switch. thank you for your help
Old Oct 26, 2017 | 03:04 PM
r_kelly's Avatar
2015 c300 mercedes
Old Oct 26, 2017 | 04:00 PM
fabbrisd1's Avatar
A gaggle of MB's
PM ItalianJoe1
Old Oct 26, 2017 | 08:20 PM
r_kelly's Avatar
2015 c300 mercedes
Tools
Someone told me that it takes this tools to remove the window panel switch and i have to force very hard! does anyone know this tool and where i look for it on the web. thank you
Old Oct 27, 2017 | 09:50 AM
2003 CL 600
Replied to your PM without looking at the pics, I was thinking of a 204 panel.
The 205 one does just pop out, put a wedge under it and lift it out. Look at the new one, you should see the different tabs on the ends, so you know which way to pry from.
Old Oct 27, 2017 | 03:58 PM
r_kelly's Avatar
2015 c300 mercedes
problem solved
Thank you, problem solved, I found a record that explains the procedure to follow. thanks a lot for your help
Old Oct 12, 2019 | 09:18 AM
Jaimem04's Avatar
C300
R_kelly;
Thanks for posting the instructions, I’m confused on one step. It says I need to unscrew something did you have to do that also? Or did it just pop off?
