C250 cam sensor fault code
Old Nov 27, 2017 | 02:15 PM
NPSDemon's Avatar
C250
Hi All,
New here. I have a 2012 C250 Blue Efficiency with 88k on it. I have run the OBD2 and it keeps giving me the cam sensor(s) are the fault. P0319 I believe. Here is where my issue comes in. I replaced both 2 months ago. Light went off for a day. Then on. Rechecked and gave the same code. I bought 2 new Bosch sensors, light went out. Came back on next time I drove it. 2 days later. Over the weekend I took a look at it. Same code. I then let it warm and shut it off and restarted a couple of times and light went off. Cold start right back on.
Any thoughts or ideas? I am stumped.
Thanks!
Old Nov 27, 2017 | 04:43 PM
DBOC205's Avatar
W205 C250BT
Not sure, but perhaps try and find someone who has an Xentry diagnostic system to run a full fault check on the car. Not all things may display on an OBD2 unit. Could be other sensors, faulty wiring harness/connectors etc.
You may also want to try posting this in the W204 forum to see if anyone there has had similar issue. This forum is for the W205 (the current series C)
Old Nov 28, 2017 | 07:34 AM
NPSDemon's Avatar
C250
Thank you. Can we chalk that up to a rookie mistake?
Old Dec 10, 2017 | 04:19 PM
maxscottras's Avatar
2012 c250 1.8 Turbo
Help
Originally Posted by NPSDemon
Hi All,
Thanks!
where are the sensors located? Looked everywhere
Old Dec 10, 2017 | 04:28 PM
2012 c250 1.8 Turbo
Here you go
Hi All,
Thanks!
magnets!
