I hastily bought some Rotiform Ind alloys and had them powder coated before fitting them. (THESE LOOK STUNNING!)
after fitting them they look as though they go past the arch quite allot!
The fitment is
front
8.5” et45
rear
10” et35
but for some reason it’s not dropping into the arch properly as the the higher the wheel goes it normally has a camber so cannot judge to see if it will fit or not
But as a dry fit with no tyre it looks the rear to be 20-30mm past the arch and front looks about 10-20mm past the front wing.
On paper should these wheels fit? I don’t know to put tyres on them and drop it down and lower it to see if the camber will clear the rear arch?
