High beam assist
Old Jan 23, 2018 | 02:30 AM
sentralfyr's Avatar
2015 S205 AMG
High beam assist
Hi
Bought a 2015 w205 with option 642 LED dynamic headlamps, is there not Highbeam Assist on these?
and what contains?235ACTIVE PARK ASSIST Can it park it self?
Thanks in advance
Old Jan 23, 2018 | 09:27 AM
PatrikN78's Avatar
S205 C180 AMG-line
Originally Posted by sentralfyr
Hi
Thanks in advance
I’ve never come across a car with the 642 dynamic led that isnt also fitted with 628 AUTOMATIC HIGH BEAM SWITCH PLUS (IHC+)
Yes, the car can park it self with your help and supervision.
You have to change gear, forward/backward.
Old Jan 23, 2018 | 10:48 AM
sentralfyr's Avatar
2015 S205 AMG
Thanks for answering
I set the light switch to auto and push the lever forward and high beam turns on, and it will not switch it self off and on,even if i meet cars or street lights.
it actually do not say 628 AUTOMATIC HIGH BEAM SWITCH PLUS my option listGeneral DataFIN
File Type: pdf
Old Jan 23, 2018 | 11:05 AM
BenDover's Avatar
S205 C200 2015' AMG Line
Hello,
I don't believe you have the automatic high beam assist as it requires option 628.
There is an easy way to see, park the car, light switch to AUTO and push the high beam lever forward, only a little high beam icon with A next to it should appear on dash and no high beams should come on as they don't work while stopped.
The 642 dynamic LEDs I believe refers to low beams following the movement of your steering wheel illuminating corners better.
Old Jan 23, 2018 | 11:13 AM
sentralfyr's Avatar
2015 S205 AMG
Originally Posted by BenDover
Hello,
Hi Thanks
I believe you are right, when i push the lever forward, it shows only a Blue headlight
