doesnt fit without spacers, HOW is it possible ?
Old Mar 7, 2018 | 11:49 AM
TigerDejan's Avatar
MB C220D
So i have a setup 19" wheels for my C220D -16 and am just wondering how in the earth its even possible that my 19x8.5 ET45 doesnt fit in front without spacers ?
Should clear without any issues imo ?!
Veemann VC7 is the wheel
Old Mar 7, 2018 | 02:18 PM
Dearsman's Avatar
C250
Considering the same wheel at the moment mate so interested to hear any reply. Can you confirm the tyre sizes you are looking at ?
Old Mar 7, 2018 | 02:28 PM
TigerDejan's Avatar
MB C220D
I have 225 front and 255 rear i think ... should be 40 and 35 but i can see tomorrow when i’m at work
Its just insane. Have to have 5mm spacers to clear
when u look at lkperformance website it says they should fit
Old Mar 7, 2018 | 02:33 PM
Dearsman's Avatar
C250
I'm getting quoted on Front 19x8.5 et42 Rear 19x9.5 et40 but I'm hoping to run F 235 40 19 and R 265 35 19 But this may not be possible ?
What you you make of the VC7 Wheel in the flesh ? did you go for silver or grey.. Interested to see how the wheels sit at the arch of the car when lowered ?
Old Mar 7, 2018 | 03:38 PM
TigerDejan's Avatar
MB C220D
ET42 and 40? Its not available for that model ?
Old Mar 7, 2018 | 04:08 PM
Dearsman's Avatar
C250
That looks great !!! do you have any closer up pictures of the wheels taking in to account the arch ? just wondering if the wider tyres would fit ? Is your car lowered ?
Old Mar 7, 2018 | 04:20 PM
Jack Olsen's Avatar
You probably understand this. But for other people happening on this thread:
ET in the wheel size is from the German word Einpresstiefe. It means offset. It's the difference between the vertical plane where the wheel hub meets the lug surface and the vertical line that would be the center of the wheel if you divided the rim portion in two equal sections. Compare the offset on your new wheels to the ones from your old (or stock) wheels to see where the tire is going to sit relative to the fender (on the outside) and the inside of the wheel well (on the inside).
Old Mar 8, 2018 | 03:44 PM
Dearsman's Avatar
C250
Hi mate, did you managed to check the tyres sizes ? Cheers
Old Mar 11, 2018 | 03:46 PM
Dearsman's Avatar
C250
Hi mate. Wondering if you managed to confirm your tyre sizes ? Also is your rear wheels 9.5" ? And offset both et45 ? With a 5mm spacer on the front.
