Very mild engine noise
So I took my car to the dealership for wrist-pin noise and was told it's the "high-pressure fuel pump" noise.
Did yours get fixed after replacement? Any more noise when you accelerate?
I was gonna take it to my dealership after being told there is no wrist-pin issue the first time I left the car with them; to have the foreman hear the noise out, but when I got there and parked the car and came back to start it again the noise was gone!
I have had left the car there before overnight, for them to check for a noise in the morning but my report says there is no issue with the car.
I don't know how I can argue or reason with them to get this fixed. Any advice anyone?
I have almost just given up, maybe I'm just being too picky about it.
You can always have it looked at by another dealership. Or a mechanic to get their impression. If you’re certain it’s wrist pin and your dealer is giving you the cold shoulder, call MBUSA and tell them your dealer isn’t fulfilling warranty repairs. But you’ll have to be certain that you have the wrist pin defect otherwise you look like an a** lol. It would be a breach of warranty (assuming you’re still under warranty) if you have that defect and they’re choosing not to repair it. But I will say the engine is inherently noisy and could be the direct injection as well
My engine No. is 274920 E0 045023. Prod. Date 05/07/2015.
The ones affected are 274 920 E0 043259 (as of about April 20, 2015) and 274 920 30 406602 (as of about March 27, 2015)
I hope that means any engine built after the cut off date is fine.
So what the dealership said could be true about the noise. "High-pressure fuel pump". Not sure they'll replace it unless it stops working, unfortunately.
also on cold days when I drive and press the brake pedal it makes a vacuum sound (like hissing ) sound...it does this only on cold days constantly...they said its normal but the 2018 c300 loaner I have doesn't make that noise on cold days.?
