Integrating with Audio20
I have a 2018 with the basic Audio20. I want to upgrade the system but I have two questions:
1. Does the factory radio supply full range sound to the doors and they use passives on them to limit low end or does even the basic radio have built in crossovers? Amplified I can see having built in crossovers but was hoping not with the basic Audio20.
2. In the event that the Audio20 radio does indeed split the bandwidth between the doors and the frontbass woofer, does the headunit have a left frontbass signal output at the connector or does it really only have 4door + 1 woofer out? I would prefer to know before I get elbow deep into the console..
Thank you in advance..
What to do with the factory signal was the big question. I'll probably justgo with a JL FiX-82 anyway so it can take care of any factory EQ as well as any signal summing if needed.
