Way too big - 20 inch Vossen VFS-4 Hybrid Forged Wheels
Old Jun 6, 2018 | 11:00 PM
paulatl's Avatar
C300
Exclamation Way too big - 20 inch Vossen VFS-4 Hybrid Forged Wheels
Just bought one set of wheels + tires, but found out they way too big... 20 inch looks very nice, but front wheels poke out 40 mm, back wheels 50 mm. there is still around 10 mm gap between front wheel and control arm.
my conclusion, if the wheels only poke out 20 mm, it should be perfectly fine, and will not scratch the fender, but anything over 20 mm, should be cautious. next round experiment, looking for 19 OEM AMG wheels, have to sell this set.
those info are your references, hope it can help. any comment?
Vossen VFS-4 Hybrid forged (http://vossenwheels.com/wheel/vfs-4/)
Wheel size:
Front: 20 inch X 9J offset: 32
Back: 20 inch X 10.5J offset: 42
Bolt pattern: 5x112
Tires: Michelin PPS tires Pilot Super Sport
Frot: 245/35 20
Back: 285/30 20
Manufacture date: first week of 2017
Old Jun 10, 2018 | 01:05 PM
paulatl's Avatar
C300
If I used 265/30/20 on the rear rim, will it still rub the rear fender? I am worried the tires may rub the rear fender when running over potholes. any suggestion?
Old Jun 10, 2018 | 01:06 PM
paulatl's Avatar
C300
guys, I need your help, please reply. thanks!
Old Jun 12, 2018 | 09:17 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
Spec for 20" Vossen on w205 should be as follows:
20x8.5 +35 Front / 20x10 +48 Rear
IF you are lowered like me, I recommend going 255 rears to prevent rubbing. I also tried a 245F and 275 rear combo and I rubbed in the rear.
The problem with your setup is that your offset is really aggressive, not just the tire width
225/35/20 and 255/30/20
Old Jun 13, 2018 | 12:00 AM
paulatl's Avatar
C300
Thanks for the info.
Agree, I just sold the wheels and tires. Do you need spacers for your current rims?
Old Jun 13, 2018 | 04:59 PM
angeloxnet's Avatar
no spacers at all in the spec I listed above
Old Jun 15, 2018 | 11:17 AM
Mike@Vossen's Avatar
Former Vendor of MBWorld
AMG
Yup those offsets are way off, Angelo has the correct offsets and they fit perfectly
Old Jun 15, 2018 | 11:19 AM
paulatl's Avatar
C300
I love Vossen wheels. they look so good~ are you guys running any promotion now? I want to buy another set~!
Old Jan 7, 2022 | 01:46 AM
matt pun's Avatar
C43 AMG
Hi, what should be the best setting if using 19" instead of 20"? Thanks.
Old Jan 8, 2022 | 05:13 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Wheel size:
Bolt pattern: 5x112
Frot: 245/35 20
Back: 285/30 20
Your front wheels look a bit bigger (to me) than the backs. 22 inch?
