Question about the Park button - had a small scare today!
C 200 2016
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi All!
New member here, and this is my first Merc - C200 with AMG Kit, 2016.
Absolutely love this ride so sweet.
Today I had a scare, called a mechanic I know he said likely no issue but to be careful. So this is exactly what happened - I am paranoid a bit and would like your expert input as well please:
So I really dislike the Parking gear button and wish I didn't have to use it. So today I pulled out of a parking spot and was approaching a roundabout at maybe 5 Km per hour I think max. I wanted to wipe the windscreen with the wipers and pressed the P button by mistake while at that (low) speed. My foot was not on the gas at that exact moment when I pressed the Park button so nothing happened and I gave a little gas to go into the round about but the engine just revved a little - I guess maybe to 2k, and then I realized what happened and as a car was approaching me from behind fast, I took foot of the gas and put into Drive. There was a small jerk as it engaged into D (at this the revs might have been around 1K or less cant be 100% sure now), but it freaked me out. After that drove just fine. To note it was in Eco mode at the time.
Question is - have I risked damage to the transmission in this scenario?![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Second question is - Why does Merc even have this feature where it locks into park if P is pressed at lower speeds, or even if a door is opened slightly at low speeds. Doesnt that damage the transmission? Cant understand why this have this feature, it should just say cannot engage in Park, car in motion??
Thanks guys! I really hope no damage was done and will be super careful now. Also is there any way to engage Park when parking after coming to a full stop without pressing that P button? I would prefer not to even touch that lever!
Nate
Nate
C 200 2016
Just to elaborate further to your reply -
1. For sure there was no clicking noise when P was pressed and engines just revved up a bit - so likely it was in neutral as you say - I can’t recall if the dash letter said N or P now but no sound
2. What is your take about the latter part though - when I engaged into drive with engine revving slightly (foot was off the gas I think) and a slight jerk was felt as D gear got engaged I guess. Any possible lasting damage there?
Based on above should I take the car to the garage to get a quick computer check done on transmission to see if any codes come up? Or am I just being paranoid here?
thanks agajn really appreciate your time.
Worry wart Nate
C 200 2016
hey sr5959 - thanks a bunch man appreciate you’re reply.
Worry wart Nate
He also said that about the gear going into D while some revs were there and the jerk, again just to be careful in future and no damage done in all likelihood as an error message would come up.
Lesson learned.
On another note:
1. Benz says that the transmission fluid is only changed at 90,000 KM or 5 years?! Seems too long to me. How often do you guys change it on newer models?
2. Is it safe to change Modes (Like Comfort, Sport etc, if car is in motion), or should it be when car is fully stopped? Mechanic said its ok to change while driving, while at stop is ideal.
Cheers,
Nate
2021 E450, 2020 C43, 2015 C300, 2007 C280
I do it every time I drive. Each time I start off, I shift into "i" for "Individual" mode. All the guys who absolutely hate the fact that the C300 always starts in "C" for "Comfort" always shift into their preferred mode while moving. You can tell that you're not moving any metal yourself. You're just changing the computer's ideas of when it should move metal.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Worry wart Nate
