User experience with the 10,25" Android screen?
Old Aug 12, 2018 | 05:39 AM
sentralfyr's Avatar
2015 S205 AMG
10,25 screen Info and install Pictures
Old Aug 12, 2018 | 01:20 PM
GJC400's Avatar
C400
That looks slick! Thanks for sharing install photos.
Old Aug 12, 2018 | 01:50 PM
sentralfyr's Avatar
2015 S205 AMG
Thank you very much.
I have not sorted the picture, they where just thrown in the album to have them for sharing
I will try to make a guide later.
Just have to figure out all the functions first.
Old Aug 13, 2018 | 06:41 AM
dheruer's Avatar
W205 C350e sedan
Has anyone installed this on a C350e (hybrid?)
How do you switch between this system and the OEM functionality?
Old Aug 13, 2018 | 07:06 AM
sentralfyr's Avatar
2015 S205 AMG
Installation on a Hybrid is probably the same as any car, you only add a couple of cables
To switch to oem you only click "Car Device" then you have the OEM screen, and you can use it as normal.
The 10,25"screen works as an Android Phone with Touch
Old Aug 13, 2018 | 07:09 AM
dheruer's Avatar
W205 C350e sedan
I guess that's a 'managable' nuisance. Most of the info can also be viewed in the dash itself ofcourse. I'm in doubt if we should get these or not :p It's nice that all other oem controls etc keep functioning.
How do you switch back from normal to this display?
Old Aug 13, 2018 | 07:16 AM
  #32
glavas's Avatar
2015 w205 C180 AMG line
Can you use original Garmin navigation on the car, can I install Here Maps an use it liko on the phone?
Old Aug 13, 2018 | 07:20 AM
  #33
sentralfyr's Avatar
2015 S205 AMG
Yes,you can use the Garmin Navigation as normal and you can use any maps/navigation you like, i have testet navigon and google maps on the android.
I really do not know if you can cange from km/h to miles and C to Farenheit
You will NOT loose any of the OEM
Old Aug 13, 2018 | 07:59 AM
  #34
sentralfyr's Avatar
2015 S205 AMG
There is a home button(A House in upper left corner) or the "back Button upper right)
The Screen works as an Android Touch phone
Old Aug 14, 2018 | 06:32 PM
  #35
dheruer's Avatar
W205 C350e sedan
From 1-10, how would you rate the experience over OEM?
on:
- Sound quality (is audio output same quality as before?)
- Image quality (same/lower/better resolution?)
- Usability (Does the screen react promptly to your input by touch? and via the controller?)
- Noises? (ie fan or something in the housing?)
- Reaction time of system vs OEM?
Any other pro's/con's you can tell about?
Old Aug 15, 2018 | 02:25 AM
  #36
glavas's Avatar
Can you make some video how it works.
Old Aug 15, 2018 | 03:43 AM
  #37
sentralfyr's Avatar
2015 S205 AMG
Smile
on:
OEM sound is exactly the same, but on the screen you can adjust the volume of several things, so when i play Spotify, i have louder sound than the OEM.(my Burmeister rocks with Spotify ;-) )
Image quality Is better
The usability is ok, but if you switch for example from OEM to spotify , the unis use some seconds to switch audio source, but thats no problem for me, and you use the controller for OEM and touch for the screen
and i think the reaction is quite fast,it uses some time to load navigation, but the OEM navigation has to load too
NO Noises at all, except if you turn up sounds in the scree you han hear some Buzzing somtimes, you just have to turn down the volume a little bit.There are No fans
Reaction time of system vs OEM, are about the same
Old Aug 15, 2018 | 03:46 AM
  #38
sentralfyr's Avatar
2015 S205 AMG
There is lot of videos on youtube
Maybe i can do it later
10,25 screen Videos
Old Aug 15, 2018 | 04:44 AM
  #39
dheruer's Avatar
W205 C350e sedan
Well that all sounds acceptable to me as well
What happens when you are in android mode and you use the controller wheel or the touchpad? Will that allow the OEM system to go through settings etc without you seeing it?
Old Aug 15, 2018 | 04:56 AM
  #40
sentralfyr's Avatar
2015 S205 AMG
The Controller wheel/touchpad only works with the OEM,and as far as i know nothing happens until you push the controller wheel, i do not remember, but i will test.
I will come back with some more asnwers when i have tested.
It is a bit learning by doing ,-)
Old Aug 15, 2018 | 05:02 AM
  #41
sentralfyr's Avatar
2015 S205 AMG
YES You can use the wheel in android mode😄👍
Old Aug 15, 2018 | 07:37 AM
  #42
400ixl's Avatar
E250 AMG Sport Convertible
wrong thread ......
Old Aug 15, 2018 | 04:43 PM
  #43
TorbenK's Avatar
C220D W205 Estate
Old Aug 15, 2018 | 04:48 PM
  #44
ItchyTasty's Avatar
2015 C300 Sport
Originally Posted by TorbenK
video is blocked in U.S. due to copyright. ugh
Old Aug 15, 2018 | 04:53 PM
  #45
TorbenK's Avatar
C220D W205 Estate
But why? Just a video from my drive way uploaded to YouTube.
Old Aug 15, 2018 | 04:56 PM
  #46
TorbenK's Avatar
C220D W205 Estate
Arh.. Just because the radio is playing some random music in the background owned by Sony.
BS!
Old Aug 16, 2018 | 03:28 AM
  #47
sentralfyr's Avatar
2015 S205 AMG
The screen also support MPH and Farenheit
Old Aug 19, 2018 | 03:43 AM
  #48
sentralfyr's Avatar
2015 S205 AMG
Nope, i think i have figured it out now, i will try tommorrow
That box with USB to the large cable harness on CD player and the other two up to the screen.
I wondered what the USB on player was, but now i know i hope.
Now i figured it out ;-) This box is connected to one of the USB connections in the armrest, i used number 1
Old Aug 19, 2018 | 09:17 AM
  #49
dheruer's Avatar
W205 C350e sedan
Has that increased stability with mirroring?
Old Aug 19, 2018 | 09:21 AM
  #50
sentralfyr's Avatar
2015 S205 AMG
The phone mirroring has not anything to do with this box, only sound
