Simple Burmester Sound Fix - Option 1 - Add A Trunk Subwoofer (JL Dual 8's)
Old Oct 10, 2018 | 06:43 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
I've had my 2015 C300 since May and although I love to drive it, the Burmester system lacks proper bass.
Front Bass is **** and even with Surround ON and set to ALL four seats, just seems like audio is all up front, so I decided to just add a trunk sub and see if the audio experience improves.
I AM SO GLAD I DID!
*DISCLAIMER* I am not a mobile audio installer or a professional. I simply asked many questions of the pros and did lots of research.
*** AUDIO EXPERTS PLEASE LET ME KNOW IF I DID ANYTHING WRONG ***
(Special thanks to Eric Cole @ JL Audio for his help)
Parts List
Step 1. Run 4 gauge power cable from the battery to the trunk, down the passenger side trim (unless your battery is already the trunk)
***Always disconnect the negative battery cable when working on this ***
Connect the power cable to the distribution block
STEP 2. Remove the extra wires from the CT10MC03 Adapter Harness and solder about 3 feet of 16 gauge speaker wire to the Front Left and Right Bass channels on the aftermarket harness. (observe polarity)
NOTE. The wire colors on the CT10MC03 Adapter Harness ARE NOT the same colors as OEM harness.
WIRE COLOR LEGEND
Sub Front Left - = OEM Pink = CT10MC03 Violet
Sub Front Left + = OEM Pink/Black = CT10MC03 Gray
Sub Front Right - = OEM Violet = CT10MC03 Violet/Black
Sub Front Right + = OEM Violet/Black = CT10MC03 Gray/Black
This is what it looks like after you connect the CT10MC03 Adapter Harness to the OEM Speaker output harness and Burmester AMP.
(No Factory wires to cut or destroy and easily revert back to stock anytime )
Disconnect the OEM connector from the Burmester AMP and connect it to the CT10MC03, then connect the other end of the CT10MC03 to the AMP.
STEP 3. Connect the Left and Right Sub Channels to the AudioControl LC2i speaker inputs, Set all knobs to lowest setting, Set AccuBass threshold all the way to the right. (Read the manual 3 times).
Leave the Bass Outputs disconnected for now.
Run power and ground wires to the LC2i and a Remote OUT trigger wire for the subwoofer.
NOTE. The LC2i has GTO Signal Sensing, which will turn the unit on when it detects signal at the input from your factory amp/powered head unit.
(This works great and it will turn OFF/ON when the factory AMP does. The LC2i will also tell the Sub to turn ON/OFF)
STEP 4. Calibrate the LC2i.
  1. Make sure the LC2i has power, ground connections and the speaker inputs are properly connected (Left to Left and + to +)
  2. Double/Triple check all connection and ONLY THEN reconnect the Battery. (Is the distribution block cover on?)
  3. Start the car
  4. Set all audio sound options, bass, treble, mid to 0 (off). (I also turned off surround)
  5. Insert a 50hz sine wave CD into the CD player.
  6. Press the volume + (up) knob on the steering wheel until you are confident it's at max volume (very important to ONLY use the steering wheel controls)
  7. Press the volume - (down) knob on the steering wheel only 3 times (you should now be at 3/4 volume)
  8. Make sure the 50hz sine wave is still playing. Use a multi-meter (set to AC volts) to verify the voltage at the LC2i speaker inputs, any channel (I used 13.49v for 3/4 volume. Max volume from the AMP read as 16.71v)
  9. Set all knobs on the LC2i to lowest setting, Set AccuBass threshold all the way to the right.
  10. Make sure the 50hz sine wave is still playing.
  11. You need to turn the bass level knob on the LC2i and until the maximized light comes on, then back off a bit, until it goes out. This will ensure the hottest undistorted output from the LC2i. More info here: https://www.audiocontrol.com/knowled...oreqcrossover/
  12. ***MAKE SURE TO TURN THE VOLUME BACK DOWN ON THE HEAD UNIT***
  13. Turn off the car
  14. Done.
STEP 5. Run the ground, power, remote IN wires to the subwoofer connector.
Connect the RCA cables from the LC2i BASS outputs to subwoofer low level inputs.
Turn the subwoofer input sensitivity ALL THE WAY DOWN (MIN)
Play a nice bass heavy audio track (I like Boasty ft Idris Elba, because the bass drop is like butter) and follow the instructions to set the correct input sensitivity for your sub.
Enjoy!
FINAL THOUGHTS
  • When the doors and windows are closed and the BASS is booming inside, you can't hear any excessive bass noise outside.
  • The BASS doesn't rattle the inside or the outside of the car.
  • The sound is 110% better with bass coming from behind.
  • ECO Start/Stop works the same and doesn't seem affected.
  • No battery drain issues. LC2i turns ON/OFF with factory AMP.
  • I use surround and even set BASS to 2. (Treble is 10, MID is 0)
  • The sub fits perfectly, but I still need to create supports to keep it from sliding back. (it does not take up much space in my trunk)
Old Oct 10, 2018 | 06:54 PM
benzdude's Avatar
Top Answer: 1
Next Phase is to try Mikes Burmester DSP AMP upgrade in the summer.
https://w205audio.wordpress.com/2016...rmester-audio/
Old Oct 19, 2018 | 02:50 PM
CaptainE's Avatar
2019 E450 sedan
Why do you need the upgraded amp?
Old Oct 19, 2018 | 05:01 PM
benzdude's Avatar
Top Answer: 1
Talking
You keep the factory amp for the center channel and rear surrounds and put the other six channels on the Audison 8.9bit DSP amp.
The Audison amp allows you to tweak the sound quality (eq, distance, frequency, filters, etc) to your liking using the PC DSP software and can also drive the extra rear sub woofer. (see the link for more info)
Old Dec 23, 2018 | 09:29 AM
Xtrm302's Avatar
2018 GLC 43
Why did you run the LC2 in front of JL Microsub?
I am also adding a JL Microsub in a 2018 GLC 43 but still trying to figure out the Bumester connector. The foot well subs are PK and VT on diagram but connector has a pair of 18 gauge and a pair of 14 gauge wires. Any idea?!
~Thanks
Old Dec 23, 2018 | 09:44 AM
benzdude's Avatar
Top Answer: 1
~Thanks
WIRE COLOR LEGEND
Old Apr 24, 2019 | 03:57 PM
benzdude's Avatar
Top Answer: 1
Adding subwoofer support and straps to have the sub stand and give my spare tire room.
26 inches of space left.
Strap hooks installed.
Old Apr 28, 2019 | 12:14 AM
Trappers101's Avatar
2016 C300 4matic
Do you know if this will work for POS Factory A20 or just for cars with Burmester sound?
Old Apr 28, 2019 | 06:32 PM
BareQs's Avatar
W205 base model (but I keep it clean)
I need a link to the subwoofer support stand please
Old Apr 28, 2019 | 08:17 PM
benzdude's Avatar
Top Answer: 1
You can add a sub to any car.
I used Home Depot Wood. Felt cloth and glue.
Old Apr 28, 2019 | 11:58 PM
BareQs's Avatar
where did u get the stands - the two pieces holding the sub upright
Old Apr 29, 2019 | 12:08 AM
benzdude's Avatar
Top Answer: 1
Walmart. They won't hold a heavy sub upright, but they will keep it from sliding backwards.
STAYHOLD.
Old Jan 13, 2020 | 12:45 PM
benzdude's Avatar
Top Answer: 1
Introduction the new AudioControl LC2i Pro and LC1i
Old Jan 13, 2020 | 01:54 PM
botaggs1's Avatar
2016 E350 4Matic Sport
Thanks for sharing. I think someone already touched on this above, but how would this change if trying to add a sub to a base Audio 20 car? Since there's no factory amp (also trying to avoid adding a DSP amp). Could you just tap into the signal from the wires in the headunit?
Old Jan 13, 2020 | 03:16 PM
benzdude's Avatar
Top Answer: 1
I would assume the base system also has some type of amplifier or the volume level would be terrible. (It may not be a fancy powerful dsp amp)
The line output converter (LOC) is only needed if you are using high level speaker input wire and want to convert it to low level RCA input to feed a sub amp. (External or built in amp)
The amplified JL audio subwoofer above can take both high level and low input (without any help), but it can only handle 5.4v max on high level inputs. Burmester L/R sub channels can go as high as 16v.
Tap into your base system front bass wires and use an LOC.
Old Jun 8, 2020 | 09:47 AM
esworld05's Avatar
2017 AMG C63
Hi, I just installed my Audison AP8.9 and for some reasoni can't get it to sound properly. I copied the tune file from ypu and Mike but it sounds pretty raw. I'm powering the front doors and tweeters, the stock subs and the rear doors off of it.
The center speaker is so overpowering that's all I hear.
Could you share how you connected your inputs and outputs? Like what speakers did you use for inputs and outputs. My AP8.9 flashes red when I connect ch 3 and 4 positives and negatives together to the stock subs. I'm not sure if thats correct.
Thanks so much.
Old Jun 8, 2020 | 10:00 AM
benzdude's Avatar
Top Answer: 1
Thanks so much.
​​​I never posted a tune file, but i can if you want.
Also, the center channel and surrounds stay on the factory amp and are several decibels quieter than the speakers on the AP.8.9. If you followed mikes instructions that would be the result.
If you meant the front audio seems louder then try setting the front subs to 500hz low pass.
Old Jun 8, 2020 | 10:21 AM
esworld05's Avatar
2017 AMG C63
Oh yes my bad I meant Mike's tuning file. My car is a c63 so I didn't use the fix82. I'm running the a pillar tweeters and the doors 3.5s off one channel.
Did you connect the front stock subs to two output leads from the AP8.9 or did you just select the bridged option on the software.
I followed Mike's installation guide but I think its my tuning that's off. Could you share yours even if its screenshots I'll copy them over.
thanks
Old Jun 8, 2020 | 10:58 AM
benzdude's Avatar
Top Answer: 1
thanks
I can later. I did select the bridged option on outputs 3/4 and 5/6. Make sure you bridged them on the correct wire + and - outputs. I believe Audison is specific about the channel and polarity when bridging. Also, my factory Burmester front subs turned out to be 2.2ohms so not sure how they worked with the Audison in bridged mode, but they did.
​​​​​​Check page 13 of the 2.0 Audison manual
Old Jun 8, 2020 | 06:17 PM
esworld05's Avatar
2017 AMG C63
Yea mine didn't work when bridged lol. It was flashing red so I'm guessing it was reading the impedance too low. I would appreciate when you have time if you could get me that file.
thanks
Old Jun 8, 2020 | 07:53 PM
benzdude's Avatar
Top Answer: 1
thanks
File Attached. FYI its not a .ZIP file.
Just remove the ".ZIP" in the name. I couldn't upload the .APS file without doing that.
Old Nov 2, 2021 | 05:24 PM
DroopzW205's Avatar
W205 C300
I AM SO GLAD I DID!
Parts List
WIRE COLOR LEGEND
  3. Start the car
  14. Done.
Enjoy!
FINAL THOUGHTS
do you need the T harness if you are using a zen tv Nav M? If not where do you get wires to connect to external amp?
Old Nov 6, 2021 | 05:36 PM
benzdude's Avatar
Top Answer: 1
T-harnees saves you from cutting oem speaker wires and provides speaker inputs and outputs. You tap into the harness not factory wires.
With Zen-m you don't need high level speaker output, but you still need speaker input from new amplifier.
ATF now sells the harness or you can but the one listed.
https://www.audiotec-fischer.de/en/match/adaptors-harnessesl/pp-
Old Nov 6, 2021 | 08:18 PM
DroopzW205's Avatar
W205 C300
https://www.audiotec-fischer.de/en/m...harnessesl/pp-
i can’t find anyone that sells it in the us only stores I find are sus. You have any link for a us supplier by chance? Also do you have to leave the stock harness disconnect frin burnmeister amp?
Old Nov 8, 2021 | 03:15 PM
benzdude's Avatar
Top Answer: 1
Sorry only Ebay.
https://www.ebay.com/itm/372116720209
https://www.ebay.com/itm/233791269027
