Navigation error (SD card problem)
Old Oct 31, 2018 | 06:29 PM
myachillesheel's Avatar
MB C250
I purchased a pre-owned C300 that apparently comes with the wrong SD card for navigation (It was probably used/switched with other car and the dealership wouldn't do anything about it because I had no dealer warranty)
This is the code that Mercedes service center suggested for the memory card: 213-906-37-05
and this is what I have on my car: 205-906-79-01
It shows an error message when I press "NAVI" and could not use the GPS so far. (picture attached)
The dealership offered $550 for a new replacement and the Mercedes Benz service center offered me $790 for it. Kinda crazy price but I saw on Amazon and Ebay that the price ranges from $80 to $130. Would they work just fine?
Can someone give me a direct link to a product that I need from Amazon or Ebay in a $100 range?
This is the message I receive when I try to use the navigation system
Old Nov 2, 2018 | 12:14 PM
MB C250
Hi guys I would really appreciate it if you could just lend a hand in this question. My car doesnt have any gps now.
Old Nov 2, 2018 | 06:13 PM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
i going to help you since i have nothing to do. haha
what year is your C300 ?
and what country are you in ?
Old Nov 2, 2018 | 11:52 PM
fabbrisd1's Avatar
A gaggle of MB's
Depending on yr - up thru 2018 - there are at least two "different" Nav card versions - both same SD card but different program versions.
If you don't have the right version of the card for your C300 - that's the "message" comes up.
Yes - you can use a eBay card - I use seller "dominorose" - just make sure you get the correct version..
Old Nov 3, 2018 | 12:54 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
2015 2016 2017 Mercedes GLC C C300 C350 Sedan E250 E350 E400 E550 E63 E-Class Garmin SD Map Pilot Ver.5.2/ Map 5.0 A2139062704 https://www.amazon.com/dp/B01MTE98MX/ref=cm_sw_r_cp_api_i_2iD3BbQNT38N2
This is the one I purchased for MY15 C300 with AUDIO20. Works great and decent price.
Old Nov 4, 2018 | 01:30 AM
fabbrisd1's Avatar
A gaggle of MB's
If you have a model year 2017 - you need to get Build Date from the Mercedes VMI/dealer record as 2017 was a split/changeover year - depending on built-date early build year can be 8.0/8.1 and later same build year changed to version 9.0... 8.0/8.1 cars won't read 9.0 - and 9.0 cars won't read 8.0/8.1
Old Nov 4, 2018 | 01:24 AM
MB C250
It is the 2015 C300 and I think it comes with the AUDIO20 instead of the COMMAND because I saw the SD card slot.
Old Nov 4, 2018 | 05:31 AM
realeric's Avatar
W205 C300, W212 E350, Q50
There are three kinds of Garmin maps.
(1) Garmin maps for non-C class
(2) Garmin maps for C-Class (2014~7/2017)(2015~2017 model years)
(3) Garmin maps for C-Class (8/2017~)(2018 model years~)
Check the seller’s description if the maps is compatible with both your vehicle class(C-Class) and the model years. You don’t need to buy the latest version maps since you can upgrade the maps within 60 days from the first activation date on Garmin website. To upgrade the maps, first insert the SD card into your vehicle, activate the maps, download Garmin download manager(PC/Mac), insert the SD card, upgrade, insert the card into the vehicle, activate it again (This means you can transfer the maps to other vehicle one time after the upgrade).
Find maps less than ~$90 on ebay (brand new only).
The latest version is software 9.0 and maps 10.0 on Garmin website as of today. For example, even if you buy 6.x version, you can upgrade to 10.0 maps within 60 days.
Old Nov 4, 2018 | 09:50 AM
ScottsW205's Avatar
17 W205
SD Nav Card or SD Slot Issue
These SD cards or the SD slot can be very finicky and schizophrenic. I have a 2018 CCoupe with Audio 20 codes 522 and 355. 2 different proper series SD cards have not worked.
Hard to determine if it’s the SD Slot or SD card. In either case they both read the dreaded NO MEMORY CARD CONTAINING NAVIGATION SOFTWARE INSERTED. So I will try 1 last card which is a 9.0 version model A218 906 30 03 and then if that doesn’t work off to the dealer possibly a software update or replacement of SD Card reader. Total nonsense on a $55K car.
