Range indicator is useless!
Old Nov 12, 2018 | 03:12 PM
sr5959's Avatar
C400
Anybody else find the range indicator annoying?
The reading goes up and down for no reason and when it’s below 25 miles it stops displaying how many miles left, that’s exactly when you need it!
This morning I filled up and it said I had 422 miles. Then I drove about 12 miles it was showing I have 447 miles!
Strange as the consumption reading is quite accurate, so it shouldn’t be difficult to calculate range accurately.
Old Nov 12, 2018 | 03:47 PM
ygmn's Avatar
2015 E400 Sedan
Range is based on speed and fuel flow so yes it constantly changes as you drive varying speeds and stop with engine running at lights etc.
It is pretty accurate but not perfect hence why at for you 25 miles it turns off as it is time to find a station 25 miles previous since yo uare running on 1 gallon of fuel sloshing around in tank....
And next fuel level is W for walk.
Old Nov 12, 2018 | 03:52 PM
sr5959's Avatar
C400
Exactly. It should be based on your average fuel consumption in the last 300-400 miles not your last 2 miles. Then it’d be much more useful.
Old Nov 12, 2018 | 04:03 PM
ygmn's Avatar
2015 E400 Sedan
Who knows what they based it on last 2 or last 40 or last 10000 but they base it on something
Mine is fine for me as once I get off interstate and start driving in town the range changes to my city driving ...
In the end I just use it to check "Hey can I make it to airport and back on what I have and still have some in the tank?"
What would be nice would be GALLONS left in tank button.
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
You can reset that as trip if you want. The range is related to mpg per current session. So if you start city and get to highway it will always go up.
I see this every day and I've never had anything wrong with it.
Old Nov 12, 2018 | 06:36 PM
rijc99's Avatar
w205
Imagine this scenario... you fill up, then drive on the highway with no traffic for 300-400 miles in to Los Angeles. Fill up again as soon as you get off the freeway. Would you still want to base the estimate on your previous 300 miles if you were going to be solely on the surface streets?
The range indicator is based on your current driving condition and style. It is giving you an approximate range based on IF you were to continue driving the same style. If you change style, IE transition from surface street to on the highway, it will change accordingly.
Old Nov 13, 2018 | 03:10 AM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
i dont know why they changed it.
on my 2003 C320 coupe, it shows the range to 0 miles. like range: 1 mile.
Old Nov 13, 2018 | 09:08 AM
splunge's Avatar
2025 CLE 53 Cabriolet
I find the range indicator very useful and accurate .It gives your range based on your current driving conditions ( speed etc ) ,not on the last 300 miles which would be totally irrelevant .
Old Nov 13, 2018 | 01:24 PM
Pointboy's Avatar
BMW 330CI
I agree with the original poster and understand how the car calculates the range but still find it annoying when it says 50 miles to empty and then 25 miles 5 minutes later and then 0 miles 5 minutes after that.
Old Nov 13, 2018 | 01:59 PM
splunge's Avatar
I've had both a C350 and a C43 and I've never seen it change that quickly , in fact I've been impressed how accurate it seems to be .. Even if you go from steady driving to stop and go conditions ( which is quite often the case when you're looking for fuel ) , the fuel consumption rate shouldn't cause such a quick change in estimated mileage .
Old Nov 14, 2018 | 06:34 PM
sr5959's Avatar
C400
Exactly.
Old Nov 14, 2018 | 07:01 PM
hyperion667's Avatar
2012 CLS63
I'm also a lover of the feature....... used it constantly in an S I had for a while, but don't really worry about it in my 63
Old Nov 15, 2018 | 09:31 AM
MBSebas87's Avatar
C300 Sport 4Matic
Makes sense tho.
